1985 300SD
Old Dec 18, 2009 | 09:40 AM
vwbuge's Avatar
'85 300SD (CA em.)
1985 300SD
Formerly a CA emissions car. Switched intake/exhaust manifold and turbo from Federal car. Starts, runs and drives great. The car was originally owned by horse stable in Southern CA and migrated to Eastern PA in 1999 or 2000. I bought the car in 2001. Since I have owned the car it has never been driven in winter and has been stored in a heated garage. There is sun fading on the roof but the rest of the car is presentable with a few minor blemishes around front wheel well. The jacking points and undercarriage are ROCK SOLID.
Interior is nice. Dash has cracks but there is a cover over it that the PO placed there. I never took it off. Drivers seat has a minor separation but still looks good. Everything works with the exception of the A/C. I replaced the compressor and drier but it quit working as it needs constant re-charging.
Car was dealer maintained until 110,000 miles. I have all other documentation for repairs. With the car goes the original turbo/air cleaner setup, original headlights and original wheels. I also have some neat stuff to go with it too. I have the documentation from the mileage badges as well as two brochures from 1985 showing the entire model line up as well as the diesels.
Some of the maintenance of PO:
new water pump
several trans fluid/filter changes
4 new shocks
5 new glow plugs
new glow plug controller
new thermostat
new hoses top/bottom
new strut supports
new heater valve
Maintenance since I purchased the car in summer of 2001:
7/1 (272,382 miles)
valve adjustment
10/1 (283,000 miles)
new left rear caliper
new fuel filters
new turbo gasket
new manifold gasket
5/02 (286,700 miles)
new right rear caliper
new center link
new tie rod ends
new rear shocks
7/02 (289,700 miles)
new driver's side upper ball joint
new steering stabilizer
8/02 (292,000 miles)
new parking brake shoes
5/03 (296,000 miles)
install new euro lights
install new wheels
5/03 (297,000 miles)
new glow plugs
6/03 (297,300 miles)
replace fuel lines between injectors
7/03 (297,800 miles)
new AC compressor and drier
7/03 (297,950 miles)
valve adjustment
remove/dismantle and clean injectors
4/04 (300,000 miles)
switch to Federal emissions
new front brakes/rotors
new front wheel bearings
11/06 (306,800 miles)
2 new flex discs
new driveshaft support bearing
new rear trans mount
7/07 (308,800 miles)
2 new motor mounts
new upper oil cooler hose
new fuel filters
1/08 (312,900 miles)
new guide rod mounts
cooling system flush/fill
10/08 (315,600 miles)
new rear rotors and pads
new front pads
new fuel primer pump
new hood pad
11/09 (316,000 miles)
new lower oil cooler hose
I am asking $4500 OBO.
The car currently has 316,xxx miles. As you can tell, I hardly drive it any more. I am looking to purchase another vehicle and this one should go. I would like to sell it to someone who will look after it like I did. I also have a Carfax from a few years ago laying around here somewhere.
The asking price is OR BEST OFFER. I realize it is a little high but this is my starting point and you will be getting a SOLID car for the money. Shoot me an email and we can talk a little more about the car and the price.
PLEASE, NO CRITICS.
vwbuge@hotmail.com
814-262-0419
Attached Thumbnails 1985 300SD-mb-close-up-side-1.jpg   1985 300SD-mb-driver-s-seat-1.jpg   1985 300SD-mb-front-1.jpg   1985 300SD-mb-side-1.jpg
