FS 1995 E320 Coupe NJ
The car has 112,xxx miles on it around. Mechanically the car is in very good condition, there has been a lot of maintenance done within the last 3-4 years. I have listed everything below that I have receipts for, as you can see there has been a lot of money spent on it recently.
Oil Service + Air Pump Replaced -1/29/10
Oil Service + Tire Swap - 5/3/10
Water Pump Replaced + Oil Service + Tire Swap + Alignment + Right Tie Rod/ Drag Link - 12/17/10
Transmission Rebuild + Head Gasket + Sunroof Rebuild - 1/31/11
4 Primacy MXV4 Tires - 3/29/11
Oil Service + Tire Swap - 4/5/11
Rear Shocks Replaced - 4/12/11
Front Brake Pads & Rotors + Flush Brake Fluid - 4/22/11
1 Primacy MXV4 Tire - 5/31/11
Oil Service + Air Filter + Drive Belt + AC Service - 8/16/11
Rear Brake Pads & Rotors Replaced - 10/17/11
Light Control Unit + Combo Switch - 11/21/11
Bosch Battery - 11/28/12
Starter Relay - 7/19/14
Right now there is a check engine light on because of an o2 sensor.
The exterior of the car has some blemishes mainly on the roof where the previous owner had the car parked under a tree and branch landed on the car causing a dent. There are other dings and paint imperfections but these are expected from a car of this age. Also underneath the headlights there is a strip that has some rust on it I am guessing from years of rock chips. All the electronics in the car work. The driver's seat is ripped in the middle where the stitching is. Also the seat belt extender has come loose but the motor still works, I am looking to see how I can fix this at the moment. I will try to get some better pictures up soon but here are a few for now. Also please call or text me if interested, my number is 908-208-5272. The car is located in central New Jersey.
Price: $4000 OBO
Attachment 445819
Attachment 445820
Attachment 445821
Attachment 445822
Attachment 445823
Attachment 445824
