ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Add me to the mix
Old Dec 30, 2006 | 06:08 PM
crjag's Avatar
Add me to the mix
Got it yesterday, coming from CTT. Nice progressive power, good brakes, seems slightly less stable over bumps but tires are too new to tell really. Can't wait to hit 1,000 miles!
Old Dec 30, 2006 | 06:25 PM
DoctorD's Avatar
AMG ML63, M3 CSL, Z4M Coupe, New Audi TT, Audi R8 (coming)
I would be interested to hear of further comparisons to the CTT. I found the power delivery to be stronger, but the ML63 is set up softer than the CTT and therefore I can understand why it lost out (in lap times) to the Cayenne Turbo S in the recent test.
Old Dec 31, 2006 | 09:51 AM
crjag's Avatar
Full comparo will have to wait until "break-in" but I always had 2 issues with the CTT: the power was always a bit of on and off, and I could never get the trans to behave like I wanted, most annoying was low speed turns where it would never drop from 3 to 2, causing lugging feeling until turbo spooled up, or you mashed it, or you manually shifted. I will wait to see if 7 speeds is better than 6 for this purpose, or if more linear approach of naturally aspirated engine makes a difference. I do miss the tilt-down mirror, but seems quieter than I expected, based on dB ratings I have seen. Reminds me of my '01 E55 in terms of power delivery, versus neck-snap of CTT, but again will need to wait.
Old Jan 1, 2007 | 08:44 AM
escapement's Avatar
I find that the accelleration of the ML vs the CTT feels about the same, without times to back this up. The power comes on more linearly in the ML. The transmission is the big difference. I could never get the CTT to downshift without giving it a lot of throttle. I went to the dealer several times for this, but they could never get the transmission to be more responsive even after replacing the controller and software. The ML is much better. It starts out in 2nd gear unless you start driving a bit more aggressively, and then it will start out in 1st. Downshifting under partial throttle is much more responsive than on the CTT.
Old Jan 1, 2007 | 08:37 PM
AMG_55's Avatar
mymbonline
Originally Posted by DoctorD
....... it lost out (in lap times) to the Cayenne Turbo S in the recent test.
what mag is the test in?
thanks
Old Jan 2, 2007 | 02:20 AM
Germancar1's Avatar
2013 650i Coupe, 2010 IS250 AWD, 1999 S500
Pics?
M
Old Jan 2, 2007 | 09:04 AM
EX-BEEMER's Avatar
'08 SL550 Sport, '11 BMW 550ix M sport
Welcome crjag!
I look forward to your comparitive insights. (the first 1000 miles are the hardest!)
