ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
W164 Front Parking Light Change
Old Sep 28, 2016 | 09:28 PM
c3nthusiast's Avatar
2008 C300
So I read about how to do this on several sites and they all basically said the same thing. Most involved a 9" needle nose pliers. Well I figured out a much easier way that will take you 20 minutes to do both sides. All you need is a short pair of pliers and a 10mm ratchet.
1. Remove the two 10mm headlight bolts. If you pull the headlight out a bit you can see the plug.
2. Maneuver your pliers behind the headlight And grad the plug. Turn it counter clockwise almost a full quarter turn then pull it out.
3. Just reverse the process to put it all back together.
