ML A/C issue
16' GLE63S AMG
ML A/C issue
Hey guys,
So I have an issue with my A/C and im not sure how to go about fixing it. I've checked the refrigerant and it's reading perfect, my controls work so it's not the little red led going. When I start the car in the morning the temp seems fine but as I begin driving, the temp starts to warm up and it seems as though the drivers side is warmer than the passengers side. Has anyone else had an issue like this?
Worst of all my screen is really starting to mess up too. One little white line has turned into multiple lines and now the screen starts getting whiter and whiter till it's completely white
Assuming you had someone other than yourself with a set of gauges who confirmed the refrig level is correct,it sounds like you have a faulty AC control module and you need someone with the Xentry diagnostic system to locate the fault, the FUYA will not work here.
