Mobile Electronics and Lighting The archived forum for mobile electronics and lighting equipment for sale by members. Browse newer listings and create your own in our new Marketplace.
Mercedes Benz B - C - CLK - GL - ML - R Class Nav Video TV Interface
Old May 18, 2009 | 12:19 PM
alweie3391's Avatar
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=110391802261
Connect A Video Input Such As A DVD Player, TV Tuner, Reverse Backup Camera, Video Game Console, iPod Video or Other A/V Source To Your Mercedes Benz B - C - CLK - GL - ML - R Class OEM GPS Navigation LCD Display Screen!
Video Modules Are Easy To Install, Activated For Video In Motion And Are Completely Plug & Play.
Product Overview:
Unleash the power of the OEM GPS sat nav system that is already installed in your Mercedes Benz B - C - CLK - GL - ML - R Class . This system module is the easiest way to interface a video source such as a DVD player, TV tuner, iPod Video, reverse backup video camera, video game console, PC, aftermarket satellite navigation system or any other AV source directly to your OEM GPS Navigation LCD screen display.
This system is an easy to install, plug and play video module that will allow you to add any composite or RGB video source to your OEM GPS navigation LCD display screen. The module works as long as you have the factory screen installed in your vehicle, regardless as to whether or not you have the nav option. This system features dual composite video inputs and one RGB input.
This system is two piece system which consists of an externally wired plug-and-play RGB module and an internal RGB circuit board which is installed within the OEM navigation head unit; it works simply by interrupting the RGB video signal from your GPS computer whenever you select the "Input" button on the IR remote that is provided. When your GPS is displayed simply turn on your external video source and activate the input on the remote control and the GPS video image is replaced by your video source, once you turn it back off, the GPS image is displayed once again.
If you are looking for an easy and affordable way to add a video input to your Mercedes Benz B - C - CLK - GL - ML - R Class GPS navigation LCD display screen, then This system is the best product for the job.
Vehicle Specific Installation Information:
This system is a two piece system that allows you to connect up to two video composite video inputs to your Mercedes Benz B - C - CLK - GL - ML - R Class original OEM GPS navigation system LCD display. The two piece system consists of an external RGB converter box and an RGB circuit board which is installed inside the car's LCD nav head unit. The external RGB box accepts an NTSC composite video input well as an RGB video input then converts them to a standard analog RGB signal, this is then connected to the other piece of the system, which is the internal circuit board installed inside of the radio. This internal board converts the analog RGB signal to TTL digital RGB that the LCD screen can then display.
The first step in the installation is to remove the head unit from the car, and open it up to expose its internal circuitry. The small RGB circuit board is then installed into the radio along with the provided ribbon cable. A small wire is then run from the internal RGB circuit board, to the external RGB converter module which is located outside of the radio. Please note that due to the complexity of this interface installation we recommend that installation be performed by a knowledgeable car electronics professional.
This system is a video input only solution, thus an FM modulator or other auxiliary audio input interface is required to bring audio into the sound system.
This system is video-in-motion enabled, so the video image will stay on the screen even with the car in motion! This unit will work in vehicles with or without the factory GPS navigation option installed, but REQUIRES the factory LCD display to be present regardless.
Why this RGB Unit Is Better Then Others:
· Professionally manufactured board in a rugged metal case.
· Plug-And-Play wiring harness for easy installation into your vehicle.
· Remote with IR extender makes controlling the unit and switching video inputs easy!
· 1 year warranty.
· High picture quality.
Works with NTSC composite as well as RGB video sources.
· Mercedes Benz B Class (2005+) - US VERSION
· Mercedes Benz C Class (2005+) - US VERSION
· Mercedes Benz CLK Class (2005+) - US VERSION
· Mercedes Benz GL Class (2006+) - US VERSION
· Mercedes Benz ML Class (2006+) - US VERSION
· Mercedes Benz R Class (2006+) - US VERSION
