Why does my 2013 ML350 Bluetec smell like pickles
After a long drive, outside of my car smells like pickles or vinegar. At first, I thought it might be a puddle, but still smell it from time to time. Usually towards the back where the back passengers exit.
Can this be from the regen process, or from the adblue heater? Dont know if the heater is always on, or when its freezing outside.
I did recently get the heater replaced under warranty. Could it be an adblue leak?
ml350 bluetec
When fairly new, mine smelled of rotten fish. It did until I found the rotten fish under the passenger front seat. Guess you lost a pickle somewhere or your just in a pickle.
Bunch of comedians. Sounds like I need to take a look at the undercarriage.
Was at a JiffyLube once, and the guy found a dead rat when he removed the undercarriage cover.
I'm in Chinatown all the time, maybe I ran over a jar of dumpling sauce.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
LOL. Seriously though - the AdBlue system is essentially urea injection which is what you could be smelling (ammonia). It could be a DPF fluid leak or simply the system working (you mentioned you just had the heater replaced... it's possible that something isn't sealed properly, but also that you're burning off soot that may not have been previously completely eliminated due to the heater failing. Have it checked if it goes on.
My preheater has the circuit open but I don't believe that could cause any smell as its function is only to warm the DEF to prevent get frozen in cold weather... but I live in Miami
