HELP: Anyone know these clip part numbers?
Old 02-14-2017, 12:35 AM
battlecat's Avatar
2014 Mercedes ML350 4Matic AMG Line, 2013 Audi A6 2.8 Quattro, 2012 Volkswagen Touareg V6 SEL
Exclamation HELP: Anyone know these clip part numbers?
Hello everyone,
Recently changed my rear brake light in the dark and lost 2 clips holding the net in my trunk (Butter fingers!). To be fair they came out when removing the net holder.
Dealer is charging and arm and a leg saying I need to buy a whole net assembly to get the clips, but I was told these are standard clip spares.
Can someone please help me with the 2 clip part numbers shown below (One with a hook that goes into the floor, and one like a grommet that goes into the trunk sidewall - Both plastic). The dealer has said if I know the clip part numbers they will order them - or else I will have to buy a whole assembly! Please help!
General Area:
Marked Clips (Floor and trunk wall)
Thank you all in advance!
Old 02-14-2017, 07:51 AM
pcy
pcy's Avatar
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Here are the clips used in the luggage area...
220 - Clip, Paneling Mounting, Right - A0009914698 (5 count)
410 - Trim Clip, Fastening for Lining - A0119887678 (6 count)
45 - Circlip, Attachment Grid 5mm 5mm - N912010005001 (6 count)
Attached Thumbnails HELP: Anyone know these clip part numbers?-ml_trunk_trim.jpg
battlecat (02-15-2017)
Old 02-15-2017, 03:19 AM
battlecat's Avatar
Thanks for your help. Unfortunately the part 205 - A1668601074; costs $120 (Luggage net whole assembly - Which comes with the 2 panel grommets and 2 hook holding clips at the bottom, is not sold individually). I ordered a wall grommet from toyota that worked perfectly - and as for the floor hook - used a blank head rivet clip that covers the hole - while one hook now holds the net. All looks stock - but sad that I had to use genuine Toyota parts in my all stock W166! Total cost for clip and floor rivet - with an extra each was $0.95.
Old 03-10-2017, 02:39 AM
K9_Benz's Avatar
w166 ml350 bluetec
Just take the from a rental, they screw out.
