2014 ML350 Cabin Air Filter Replacement
Old 03-28-2017, 09:41 AM
pulwama62's Avatar
2014 ML350
Recently bought a 2014 ML350. Looking to replace the cabin air-filter. There seems to be two approaches, either from the glove compartment or from the engine compartment.
I tried the glove compartment approach and think removed all the torx screws etc., but could not completely remove it. It seems to be sticking on the left side and didn't want to force it open.
Any suggestions?
Old 03-28-2017, 01:35 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Try harder!!
Old 03-28-2017, 02:39 PM
pulwama62's Avatar
2014 ML350
Thank you.
Well, it was an oversight on my part. 2014 model has a additional torx screw holding the glove compartment. It is kind of hidden in the lower left corner, between the molding. The whole process is pretty straight forward once you get the screws figured out.
My ML350 has an air duct feeding the glove compartment, which also needs to be pulled out AND reconnected during the process.
Old 03-31-2017, 11:03 AM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
moved to W166 forum...
pulwama62 (03-31-2017)
Old 03-31-2017, 05:48 PM
DanD.'s Avatar
2018 GLC 4MATIC
Here is a nice video on how to do it from outside.
peter2772000 (05-04-2017)
Old 04-08-2017, 09:21 AM
jrsmith_68's Avatar
2007 C350 2015 ML400 1968 Ford Mustang
There are two filters, one inside and one outside. You have to do both.
Old 04-08-2017, 08:36 PM
Ellacino's Avatar
Mercedes Benz ML350 Bluetec
Hi pulwama62, would you mind me asking what prompted you to change the cabin filters, were you getting a bad smell from the aircon at times. You may be interested in my thread about the aircon in my ML350
Old 04-22-2017, 04:03 PM
k9lovr's Avatar
2014 ML350 Blutec
I just did this today using the video from above...literally took me 15 minutes...so much easier than pulling the glove box...I used Mahle filters and they worked great
Old 04-22-2017, 06:18 PM
pulwama62's Avatar
2014 ML350
Hey Ellacino, I bought my MB recently and I went ahead and replaced the air-filter and cabin filter. I also knew the first owner had pets and I wanted to make sure there wasn't any residual pet hair in the car.
Old 04-22-2017, 07:44 PM
DanD.'s Avatar
2018 GLC 4MATIC
Can you provide the link where you bought them? OEM filters kind of expensive.
Old 04-22-2017, 08:18 PM
pcy
pcy's Avatar
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Try AutohausAZ.com or RMeuropean.com
Old 04-22-2017, 08:55 PM
k9lovr's Avatar
2014 ML350 Blutec
rockauto.com
Old 03-01-2020, 08:24 AM
frank94's Avatar
2015 Mercedes-Benz ML 350
I have 2015 ML 350 , wonder how many air filters? left and right one?
Farnk
AeroRamer (03-01-2020)
Old 03-02-2020, 02:40 PM
Chamelleon's Avatar
ML500 and ML350 BT, 2015
Mine is the same year and model.
You were right. There are two air filters (left and right).
I'm changing them every second oil change.
Old 03-03-2020, 11:18 AM
frank94's Avatar
now get me really confused, I called benz dealer, gave them my 2015 ML 350 VIN, and they said it is only one air filter with part # 276-094-0004, may be you mean by one air filter and cabin filter? I saw some video, it located on the left side of engine bay, there is two E-10 schews right?
Frank
Old 03-03-2020, 11:23 AM
frank94's Avatar
i saw the video above, even says for w166 ML 350, but looked at the oil filter it is different then the one I ordered, it only has one big O ring, one small O ring already on the filter, the video shows one big O ring and two small one, and engine cover is different then my 2015 ML 350.
Frank
Old 03-03-2020, 01:07 PM
Chamelleon's Avatar
Mine is a diesel version of 350 ML, Bluetec.
If yours is 350 gasoline then you might have only one.
Old 03-03-2020, 03:32 PM
frank94's Avatar
Thanks a lot Chmelleon.
Frank
Old 03-04-2020, 11:48 PM
we47b1me's Avatar
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
Frank
you guys are all over the place...
are you asking about ENGINE AIR FILTER, or the CABIN AIR FILTER???? The latter is the topic of the post. They are DIFFERENT filters!
Quick Reply: 2014 ML350 Cabin Air Filter Replacement
