Smelly aircon ML350
Old 04-06-2017, 09:05 AM
Ellacino's Avatar
Mercedes Benz ML350 Bluetec
Smelly aircon ML350
Hi for some time I've had an issue with smelly aircon on my ML.
No problems if started from cold but on restart there is an awful musty doggy smell from the aircon. It clears after a few minutes.
MB have had it back and have cleaned the evaporator by a couple of methods, changed the cabin filter, deodorised etc but it always comes back.
Not sure if it's related but it never drops water from the aircon like every other brand of car I've ever had. MB says the drain has a deliberate restriction and the engine has to be running to blow the water out, even then I've never seen anything. They say they've checked it and it's ok.
My gut feel is that it's water related, maybe stagnating somewhere.
Any help or experience would be gratefully received
Old 04-07-2017, 03:22 AM
350MH83's Avatar
2017 GLS 350d
This is a very common problem with MB. It affects more than just the ML, most models can have it. I had it on my ML350 BT (2013). I dont have it (at least not yet) on my 2017 GLS.
Old 04-07-2017, 05:13 AM
Ellacino's Avatar
Hi,
Thanks for that, did MB or you ever resolve it ?
Old 04-07-2017, 05:31 AM
350MH83's Avatar
2017 GLS 350d
I got the AC sprayed with some chemicals once by an MB dealer. They had an advertisement on the front door specifically for this thing to treat smelly AC systems, so I guess I wasnt the only one complaining about it. It made things better, after some months I think I was able to smell it again sometimes but at a lower level. Then I totalled the car so never got the issue again Maybe with a couple more months it would have come back to the same level.
Old 04-07-2017, 09:06 PM
Ellacino's Avatar
Can you remember if you ever saw water under your car from the air conditioning, we never do. Every other car I've ever had drops water from the aircon. Australia gets pretty hot and I think that the problem is more noticeable in the summer and will lessen now it's Autumn. Perhaps the problem isn't as pronounced in Europe.
Old 04-08-2017, 05:16 AM
350MH83's Avatar
2017 GLS 350d
I dont reckon having seen a puddle of water under my car. But I believe I have seen water drips, just not enough to form a puddle. As you say, maybe there is a system that prevents the system from draining while the car is stopped.
Old 04-08-2017, 08:46 AM
easyedwin's Avatar
GLE 350 4matic-Porsche Cayman
Splash guard under engine prevents floor spotting.
Spray Lysol onto the air intake at the bonnet [hood].
Old 04-08-2017, 12:06 PM
DanD.'s Avatar
2018 GLC 4MATIC
I saw a lot of videos on youtube
Like this one
People use steam cleaner for air vents cleaning.
Personally I didn't try it yet.
Old 04-08-2017, 08:43 PM
Ellacino's Avatar
Hi easyedwin, dand and 350MH83
Have any of you guys had the smell ?
Old 04-08-2017, 08:45 PM
Ellacino's Avatar
Sorry 350MH83, just realised you already said you did
Old 04-08-2017, 10:35 PM
DanD.'s Avatar
2018 GLC 4MATIC
No I don't.
Old 04-09-2017, 09:57 AM
pcy
pcy's Avatar
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
To prevent mildew and related smell from AC vents, what I do is turn off the AC and turn on just the fan for 10 minutes before I reach home/destination (to dry out the heater core). This works for me.
Old 04-09-2017, 10:35 PM
DasSchnitzel's Avatar
ML350 BlueTec
I agree. Your evaporator has some mildew on it. What state are you in and where is the car from? Can spray it down with an AC coil cleaner and run tons of hot air through it yourself next time. I've had this happen on every car we've ever owned in FL.
Old 04-14-2017, 12:31 PM
boydenmb's Avatar
ML350 Bluetec
Do you have a diesel or a gas model? I have heard that an ammonia smell is common in the diesel engine model and mine is worse with the a/c on.
Old 04-16-2017, 04:58 AM
350MH83's Avatar
2017 GLS 350d
I had the diesel one. And it is true that if you stop the AC before arriving at your destination there will be no smell on next start.
Old 04-17-2017, 03:10 AM
yavor's Avatar
Mercedes GLE 350d 4Matic
I had this problem on my previous bmw. It happened mostly when the temperature outside was close to the chosen temperature inside, as if the system should intake outer air almost without chilling it. I just moved the temp down to start blowing colder air and the smell stopped .
No such problems with the gle for the moment.
Old 04-18-2017, 09:25 PM
jimmysanjuan's Avatar
2023 GLE 53
I finally got this resolved. Mixed a spray bottle with one quart Isopropol Alcohol, 2 drops of Dawn, and a liberal spray of Pure Citrus lemon oil freshener. removed the cabin filters, ran the car and heater on high with windows open while spraying the mixture thru the fan (slowly so that it wasn't pooling and not getting to the evaporator area) Took a few minutes of patient spraying to get it all thru the system. Let the car continue running with heat on high for 10 more minutes to thoroughly dry everything up. Replaced the filters with new Mahle filters. It's been a week, and all seems OK. No more stink on startup. I've used the commercial/professional products before, and this worked better.
Old 04-23-2017, 09:43 AM
ML350Montreal's Avatar
2012 Ml350 Diesel (AMG PACK)
i had the same problem and changed the cabin filters
Quick Reply: Smelly aircon ML350
