Oil Part #, confused now. Please confirm the part #
Hello,
I decided to do the oil change near the house,
and provide oil and filter to the tech.
Looked at my last oil change at the dealer to get oil part # and order it on-line.
Part # shows as
001-989-37-01-USA9 5W-30 MB229.52 BUL
Placed an order with http://www.mboemparts.com Provided VIN #.
Got a call, this oil is not for diesels and they telling me the right one is 001-989-37-01-USA6
Dig in to old receipts and found my old oil change at different dealer and part # was 001-989-37-01-USA8
So now I have three different part numbers.
Can some one tell me which is the right one for
2014 ML350BT ?
Thank you in advance.
Part # shows as
2014 ML350BT ?
You are confused over nothing----the three part numbers are the same 001 989 37 01 and the oil spec is per MB 229.52---now if it is\was applicable to the car you check by VIN!---what's the VIN?
In the normal manufacturer's world, all parts could be very different.
Here is the VIN: 4JGDA2EBXEA326809
ML maintenance book recommending oil 229.51 for BT engines, but dealer used 229.52
and they don't have 229.51 in stock.
thank you for looking.
The following multi grade Low SPash oil specs apply to your to your 642.826 engine(with DPF)
228.51---5w30 000 989 94 01
229.31---5w30 000 989 93 01
229.51---5w30 000 989 97 01
229.52---5w30 000 989 37 01
Take you pick!
229.52
Take you pick!
229.52
Thank you for your response. I pick what dealers are using 229.52 5w/30
But what usa6, usa8, and usa9 at the end of the part number means? Is this something dealer specific?
Originally Posted by Plutoe
Ask a dealer!
They have changed specs so many times and no data or documentation released on their own oil that it's hard for a dealer to recommend anything other than what is in your manual.
Problably thank the EPA for that and their mission to force manufaturers to protect the DPF system at all cost. they forgot the rest.
I just received the oil from online seller.
Oil labeled 04/14 its 3 years old.
Please see photos.
I searched online for engine oil shelf life, no real answer. Its between 2-5 years.
Is it safe to use this 3 years old oil?
Please see photos.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Yes, that's a fully synthetic motor oil and is perfectly good even after it has been sitting on the shelf for three years, and it is the correct oil for your BlueTEC ML.
MB 229.51
Low SAPS Long Life engine oil for diesel engines with particle filter meeting emission EU-4 -> standards.
MB 229.52
Oils meeting this specifications must have lower ash content, at least 1% better fuel economy compared to the requirements of MB 229.31 and MB 229.51 and better oxidation stability for biofuel compatibility. Can also be used where an MB 229.31 or an MB 229.51 oil is required. Just like MB 229.5 and MB 229.51 this spec requires a long life oil.
MB 229.52
