Diagnosing and fixing Parktronic failures?
Just bought a 2012 ML350 and its only problem is that Parktronic is defective. I get the 2 red lights plus tone that indicate I need to bring it to a dealer.
Does anyone have any experience diagnosing individual sensor vs wiring harness failures with Parktronic?
Seems to be the exact same system as the W212 and W204 models, but failures seem to be so rare that there's no SOP for how to actually diagnose and fix that generation of parking sensors.
You will create more expensive problems----do yourself a huge favor find someone with a copy of factory diagnostic software-----they will find the problem in thirty minutes---your way--sell the car or donate!!!
If nothing more access MB Startek WIS for wiring diagrams,but then how will you test without the diagnostics--this aint a 63 ford!!
I've attached a photo of the affected sensor. I'm hoping there's a way to access it without removing the full bumper (just the grille). Does anyone have any suggestions?
Thanks in advance.
You're right, and I forgot to mention that I already had a dealer appointment. I was worried that they wouldn't be able to narrow things down, but luckily they found exactly which sensor was damaged.
Thanks in advance.
Thanks in advance.
Nvm, I managed to get WIS to work. I'll try removing just the grille to install the replacement sensor when it arrives. If that doesn't work, the bumper will have to come partially off.
Hi Sadpada, how did you remove the grill? I need access to front sensor under the day running light. Do you have instructions to do this please? TIA
