2012 ML350 Command Error solved
Hi Guys
Since beginning of this year I was looking for the solution for my command system (which turn off and on itself and can not use any)
I will explain detailed symptom and every effort i did and finally the solution.
I am not mechanic but my engineering major helped me little bit to solve
So I hope this trick works for your situation too.
First of all, my car is 2012 ML350 so, it will be the W166 chassis, I am not sure this will work for the older version
1. What Happened
After I turn on my blue tooth (which I linked before) and plug in USB cable to charging my Samsung Note 3.
No problem was found before I unhooked the phone.
2. Symptom
Command screen keep on and off by itself and I can not control anything. Actually just few second at the beginning when it started then I can move knob,but back to freeze.
But funny thing was, when I turn off the command screen, and check my dash screen (I change the menu to navigation on that) it still shows my direction and street name on the screen.
So I guess navigation is still working but it does have problem to show on the command screen.
3. What I tried
I tried so many things which shows online
A. Check the fuse (unplug, wait certain time and plug back)
B. Disconnect battery ( I even discount 2ndary batter - EMB or something) and wait couple of hours - It only reset the clock
C. Even tried ECU reset - nothing happened.
D. Ask dealer, and they said I need $140 diagnosis test to find out - I said too much for check
E. Someone said online, maybe fiber optic issue - I don't have tools and I do not want to tried that much thing.
4. Find solution accidently
So, I almost forgot, but someday I just concern that why system keep start over and over.
For me it looks like kinda PC (Personal computer) symptom, when I insert wrong operation CD in the computer.
Then I tried to eject CD from the command system.
That was kinda tricky, because when hold the eject button, it does not work.
I push spontaneously every half second.
And walla!!
After CD ejected (The stupid CD which my wife's friend burned couple of music in) all works fine.
So I guess, wrong CD keep trying to run and system could not recognized.
But one more thing is, you have to have a same symptom I had to solve the issue.
Like screen powers on, when you turn off the screen still direction shows on DASH screen.
So try this CD eject trick and I hope it help you guys from ridiculous expensive charge to fix.
Good luck and drive safely
1. What Happened
2. Symptom
3. What I tried
And walla!!
The following 4 users liked this post by jpntoys:
Thank you!
Thank you for this! All of a sudden today this happened to mine, we tried resetting it and even took out the unit... My husband gave up and said we had to buy a new one, this one was fried. I was researching and researching and came by your post and asked my husband if he ever played a cd in the car. He thought I was nuts but went out, kept playing with the eject button until an old cd popped out and now it works!
I just wanted to thank you for sharing your post. I own a 2012 ML 350 and I had the same issue as you stated. Turns out that when I bought the vehicle used 2 years ago there was a CD in it I did not know about. I followed your steps and it worked. My command control center is working normal now. Thank you again for sharing. You saved me $$$
Tracy
Tracy
Not sure why the Command Control on my wifes 2012 ML350 started to malfunction? After pulling fuses etc and reading thread after thread about different fixes, I came across jpntoys thread about removing the CD in the drive. I was able to eject the CD that had probably been in there for several years and Wha-Lah success!!! Thank you for sharing this post. Seems to have solved the issue, in addition to saving me time and money!
Hi Guys
1. What Happened
2. Symptom
3. What I tried
And walla!!
1. What Happened
2. Symptom
3. What I tried
And walla!!
Same thing happened to my wifes a couple years back! Ended up there was a CD in the drive. Once we were able to get the disc out. Everything went back to normal. I cant believe MB doesnt tell people about this possible fix!!! We recently got rid of the vehicle and are now onto a 2023 GL450. Cant wait to try to diagnose those electrical nightmares!!! Til next time. Cheers!
