2007 e350 4matic Indicator Lights
Old Dec 6, 2013 | 02:14 PM
jalueras's Avatar
e350 4matic
I have a 2007 e350 4matic and the only indicator light that is functional is the Seat belt light. That light stays on even though all seat belts are connected. None of the other lights illuminate even when the car is on auxiliary not being started. None of the interior flashers light up yet all of the exterior flashers are fully functional. Hazards same issue no lights illuminate on the instrument cluster. No check engine light on auxiliary. I ran the car down to the point of empty to see if the gas light would turn on and to no surprise no illumination warning low fuel. If I turn on my high beams the interior indicator does not illuminate even though they are externally functional. I have had a diagnostic done and there was nothing wrong with the SAM Module and found that there are no Fuses burnt, also found that there were no shorts therein the instrument cluster. Need help! Does anyone have the same issue regarding non functional indicator and warning lights?
