Sl500 abc
Old Sep 27, 2014 | 08:11 AM
Timmyt's Avatar
Sl500
Sl500 abc
Hi I have a sl500 w230 and have a problem with the abc after sitting for a while one side would drop so got my local garage to clean the abc valve block after refitting and topping up fluid when started the back went straight to top setting could not ajust on button then fluid started to leak from rear valve block on inspection the rear valves had popped there tops off and leaking fluid
My Q is if the abc has not been bled would it cause this problem
Old Sep 28, 2014 | 11:36 PM
AmgSeahawker's Avatar
08 clk63, 06 E55, 05 c55, 14 ml350, 98 pathfinder. Have owned cl55, s55, cls55, c230, cl500, cls500
The valve block should not leak at all. Doesn't matter if the system was bled or not. If you need a new one, I believe my buddy has a new one that he didn't insatll and sold his car.
