Air Conditioner...
Air Conditioner...
Hi guys,
how can i turn off the Air Conditioner completely? there is no option in the menu
the lowest airflow is 1.
Plus my fuel in the display goes off like this 100%-95%-90%-85%
is this normal?
is this normal?
Did you try the instructions to turn off HVAC from your user manual:
http://moba.i.daimler.com/baixn/cars...7e6801940194-4
The fuel display usually goes down when you drive the car and then jumps up when you fill it.
The lower than 1% granularity is likely to reduce fluctuation and to match the meter accuracy.
EDIT: seems the direct link does not work. European user manuals can be found from this address:
http://www.mercedes-benz.de/content/...ve_manual.html
It gives you a German language manual first but almost any other language can be selected.
Received 3,353 Likes
2012 CLS63
have to use your command knob to scroll to the bottom of the screen and tap on the actual AC, where it says ON........
also have you tried the keypad? after your hot star it has a second funtion
Isn't that turning AC off, not the whole HVAC. Actually I'm not sure what the OP wanted to achieve but my interpretation was "HVAC off" which also turns the heater blower off.
Yes, sorry, it was actually clear from your first post. But can you clarify the AC related question or did you already figure that out. Do you just want to switch the AC compressor/cooling completely off and keep the rest of the HVAC on (which hyperion already covered)?
If you were able to switch AC off, you should have noticed the menu "Climate ctrl on/off". See instructions attached (these are from the Euro manual, I did not check if it is different on the US manual).
press the menu button in the middle of the console then use the hockey puck and pull to select climate contorl off, or a/c off. Unfortunately it does not have a off button but that is what the push knobs for the vents are for.
2012 CLS63
Frigidaire 12,000 BTU 115V Slider Room Air Conditioner w/ Full-Function Room Control is the best portable air conditioner known to me so far. It quickly cools a room up to 550 sq. ft. with de humidification up to 3.6 pints per hour. It fits nicely in a small window that slides sideways instead of up and down
WUAWWW!!!
much fancy, such humid, lot cold
