S-Class (W222) 2014-2020
AerowerkZ Integrated Dash Camera for W222 S-Class
Old 05-17-2017, 07:02 PM
Former Vendor of MBWorld
AerowerkZ's Avatar
CLA250
AerowerkZ Motorsport is proud to announce Integrated Dash Camera for W222 S-Class.
Our dash camera is integrated into the cover and replaces factory cover for discreet design and perfectly centered recordings.
  • Price: $199
  • FREE shipping to continental US for forum members
  • No cutting of factory wiring harness
  • Available in black, gray and beige colors
  • Full HD recording at 30fps
  • H.264 compression
  • MOV file format
  • Audio recording
  • G-sensor
  • Aperature: F1.8
  • Field of view: 155°
  • Sensor: 1/3" Color CMOS
  • Fuse box connection
  • 1-year warranty
  • 8GB microSD card included (supports up to 32GB)
  • Built-in WiFi
  • iOS app
  • Operating cabin temperature: -4~176°F
  • Professional installation is strongly recommended
S-Class model shown in beige color.
Installed photos on W205 C-Class
Attachment 442200
Attachment 442201
Actual demo video footage
iOS app demo
Download APK for Android
Install Guide (PDF)
Old 05-17-2017, 07:39 PM
mrpcar's Avatar
2002 Ferrari 360 spider, 2012 BMW X5M, S550e, 2014 Prius plugin
How do you run the power to it?
AerowerkZ's Avatar
CLA250
To the fuse box.
Old 05-17-2017, 07:44 PM
mrpcar's Avatar
So I have to run it all the way down through the pillar to the fuse box down below? Isn't there a way to grab power from the rear mirror area? TIA
Old 05-17-2017, 07:55 PM
AerowerkZ's Avatar
CLA250
Technically yes so that you don't tap into factory wires.
But, you can grab acc wires nearby the dome light.
Old 05-19-2017, 12:35 AM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Need more Info...
I think its a great product to be integrated, but we need more information...
Does it have a backup battery?
Can your connect it to
How do you watch the footage?
Can you add a rear camera?
etc....
You WEB site does not show any other information, only a video
Old 05-19-2017, 12:43 PM
AerowerkZ's Avatar
CLA250
https://www.youtube.com/watch?v=L2YZMNrbWUg
etc....
There is no backup battery.
You can connect to Cellink, but requires hard wiring.
You can watch either by removing the microSD card or via iOS app.
No, we don't have rear cameras.
We will be working on the website.
Old 05-25-2017, 02:09 PM
AerowerkZ's Avatar
CLA250
Updated original post with iOS app demo video.
Old 05-26-2017, 02:13 PM
AerowerkZ's Avatar
CLA250
Happy Memorial Weekend
Old 05-26-2017, 10:56 PM
Nice Ride's Avatar
Can you explain Parking Mode setting on the app....
Old 06-09-2017, 10:17 AM
AerowerkZ's Avatar
CLA250
Friday
Old 06-11-2017, 11:17 AM
AerowerkZ's Avatar
CLA250
When parking mode is enabled in the app, the camera records only when motion is detected while the vehicle is locked/parked.
As mentioned earlier, we don't recommend using parking mode.
Old 06-11-2017, 11:32 PM
Nice Ride's Avatar
Possibly I missed the reason not to use parking mode....
Can you set a Battery cut off voltage instead of ACC on/off?
If you use cell link, the unit will turn on with acc wire, then when the car is off, parking mode will run off of the Cell Link battery till CLB goes low. Once the car is started again the Cell Link battery will be recharged. This should keep all battery issues to a battery that is designed to be drained and recharged often. What's your thoughts...
Any future ability to use a larger memory card...
Old 06-12-2017, 09:04 AM
AerowerkZ's Avatar
CLA250
There is no setting for battery voltage cutoff.
If you use Cellink, technically you won't have car's main battery drainage issue.
With current hardware, 32GB storage is maximum.
Old 06-13-2017, 02:12 PM
Tjdehya's Avatar
2023 EQS 580
Is it completely passive? As in, does it automatically start when I start driving and stop when I park. Does it automatically record over the oldest file when the storage is full? etc.
Old 06-13-2017, 02:25 PM
AerowerkZ's Avatar
CLA250
It starts recording when ignition is ON and stops recording when ignition is OFF.
When storage is full, it starts to overwrite the oldest file. If there is recorded video that was triggered by g-sensor, that file is protected and won't be overwritten.
Old 06-13-2017, 09:33 PM
Nice Ride's Avatar
So, If I Velcro the CLB to the Main Battery in the trunk, and wire the CLB to Charge when Ignition is on, does your unit have more than 1 power lead?
CAR BAT + -
CLB + - ACC
AERO + - ACC
Old 06-14-2017, 12:31 AM
AerowerkZ's Avatar
CLA250
CAR BAT + -
CLB + - ACC
AERO + - ACC
It should be something like this.
ACC wire -> ACC fuse box
BATT wire --> CLB --> BATT fuse box
Old 06-15-2017, 08:14 AM
Nice Ride's Avatar
So parking mode is automatic if it is set in the app.
Car Starts, normal recording. Car off, Parking Mode active till CLB Battery Dies? No low voltage cut off? I guess that's why you do not recommend it its connected to car battery...
Old 06-15-2017, 12:32 PM
AerowerkZ's Avatar
CLA250
That's correct.
No low voltage cut off from the app.
Old 06-21-2017, 12:00 PM
AerowerkZ's Avatar
CLA250
hump day
Old 06-21-2017, 01:55 PM
AerowerkZ's Avatar
CLA250
Due to high demand, we are releasing APK file for Android users.
Download link has been updated in the original post.
Will update once it's officially at Google Play store.
Old 06-29-2017, 12:04 PM
AerowerkZ's Avatar
CLA250
Old 07-11-2017, 02:46 PM
AerowerkZ's Avatar
CLA250
Old 07-13-2017, 10:19 PM
AerowerkZ's Avatar
CLA250
Before installing on S-Class.
After installing on S-Class.
Quick Reply: AerowerkZ Integrated Dash Camera for W222 S-Class
