rattles
Have someone drive the car while you press on different surfaces/areas until you identify the spot...the fix (normally some felt tape/foam) is then the easiest part once the source is found. You can also lightly pound around the area(s) you hear the rattle coming from then press firmly while lightly pounding until it stops.
