S-Class (W222) 2014-2020
B$#*!Meister Stereo
Old Feb 20, 2018 | 08:08 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
B$#*!Meister Stereo
Any suggestions on how to improve the bass response on the Burmeister System. Low volume sounds fine but bass gets washed out when you turn it up. My HK system in my W221 was dramatically better on the bass front, this one sounds washed out.
Old Feb 20, 2018 | 09:14 PM
1bad540's Avatar
s550 Diamond white amg pano
-somethings wrng w it, mines way better than my 221.
Old Feb 20, 2018 | 10:18 PM
Bluemax's Avatar
15 S550 Daily 96 Dodge Viper GTS
+1
Old Feb 20, 2018 | 11:03 PM
lh713's Avatar
2015 GL63, 2015 S550, 2006 SL55
Are you referring to the Burmester High End? I’ve never heard better base, even from an indoor audiophile setup.
Old Feb 20, 2018 | 11:07 PM
superpop's Avatar
Regular Burmeister. No oomph in the base.
Old Feb 20, 2018 | 11:16 PM
Cartman417's Avatar
Range Rover
How do you know if you have regular or high end?
im adding a 12” sub in the trunk of mine custom box
Old Feb 21, 2018 | 02:01 AM
Wolfman's Avatar
Super Moderator
The HK System in the W221 is pretty crappy and nowhere close the standard Burmester, let alone the 3D. This likely sounds like the sound settings unless you listen to Sirius which will sound horrible on anything. Can you post your settings (pics)?
Old Feb 21, 2018 | 10:12 AM
superpop's Avatar
I have surround on and eq set on a pretty typical curve. Sirius does sound crappy but that has always been the case. Direct connect to my Iphone sounds the best and some of the HD FM channels sound pretty good. Bass just seems flat or too boomy if I turn it up. Maybe I am just used to the sub sound coming from the rear package tray on the W221. Not sure where the sub drivers are on the W222.
jrpisha's Avatar
2023 AMG SL55,2015 S550 4MATIC, 2023 BMW X5
I have the same issue with the standard Burmeister system in my 2015 S550. The in-cabin front mounted subwoofers are small, thin, and have no baffle space. To bring significant bass response into the cabin, you'd need to replace the factory subwoofers, amplifiers, and add an equalizer. It can be done, and but you'll lose cabin and/or trunk space.
Overall, the standard system lacks depth. In my opinion, all of the drivers themselves are too small, they're not of high quality, they're mounted in tight spaces (no baffle space nor sound deadening material), and the factory amplifier isn't of sufficient wattage to power them. The saving grace is the digital signal processor that creates the surround sound effect - it does a nice job filling the cabin.
Old Feb 21, 2018 | 10:23 AM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
Once again it boggles my brain that one buys a 100k automobile and then has to gut the speakers and amp. and have to replace to have a decent stereo system......
Old Feb 21, 2018 | 11:00 AM
Socalsteve's Avatar
2015 MBZ S 550
The 3D Burmeister option is pretty amazing. No need to do anything aftermarket. Sounds awesome! And this is coming from a person who’s first career in life was as a sound engineer in a recording studio.
Also, it’s a car. It inherently is not going to ever come close to a home stereo system. How could it? You would have to sit in the back of the vehicle, in the center and have so much sound deadening done, it would be stupid expensive and heavy. And, this is only for stereo imaging and lack of background noise. So much else goes into a high end stereo system that a vehicles environment could not ever come close to achieving.
Old Feb 21, 2018 | 11:29 AM
I realize the inside of a auto is not the perfect place to listen to stereo compared to some wonderful acoustic room. What I am saying is that for a 100k+ vehicle one would expect the very best set up. My Ford F-150 pickup has a factory installed Sony system with a football sized sub woofer under one of the rear seats and the quality of the sound is worlds better than my 2017 SL450. Even with the engine off sitting in the driveway the system in the SL is sub par. I would expect that MB would put the best of the best in the whole S series.....
Old Feb 21, 2018 | 02:16 PM
Socalsteve's Avatar
2015 MBZ S 550
So, there are 2 seperate things going on here. Physics and culture. I’ll start with physics.
To get bass frequencies you need to push a lot of air. To do this and make the bass sound musical, you need a tuned enclosure, lots of power and a way to cut off higher frequencies from transmitting through that large speaker. The nature of your pick up truck with lots of interior space and a back seat lends itself to designing and installing an enclosure that will allow for decent bass frequencies. Your roadster, on the other hand, does not. It has no backseat and very little room for any type of large speaker or enclosure. For that matter, it also does not lend itself well to any other speakers in doors, dash, etc. in comparison with a full sized truck. So, it is truly comparing apples to oranges.
Now onto the cultural aspect. Until recent times, German cars had no cup holders. Do you know why? Because the Germans felt that you should not be distracted while driving 100 plus mph ( or 160 plus kilometers) down an autobahn. What they did do was make a very safe and fast car. One that had a powerful and torquey engine, that handled well and had large brakes for quick stopping power. The stereo and cup holders were a pretty distant priority.
Onto to modern day. Yes, America makes up a great deal of German car sales and we need cup holders large enough for our Big Gulps and we also have a culture of wanting loud and booming stereos in vehicles. So, the Germans aquiessed and gave us cup holder ( maybe not large enough for Big Gulps ) but it’s a start. What they didn’t and couldn’t do in a roadster ( due to limited space and the priorities mentioned above ) is make a vehicle with a big boomy sound system. What they did do is makes some of the finest vehicles on the planet.
Old Feb 21, 2018 | 03:10 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
You'd have these awesome rotary tweeters that also shoot out the same color as the ambient lighting:
Old Feb 21, 2018 | 04:40 PM
coolcamden's Avatar
2021 E63S Wagon 2019 S63 AMG Coupé 2015 S Coupé Edition 1 1970 Chevelle LS5
The Coupe does not have rotating tweeters. The grill just simply says. “High End”
Old Feb 21, 2018 | 04:56 PM
konigstiger's Avatar
'71 Pinto
See attachment for coupe.
File Type: pdf
Old Feb 21, 2018 | 09:35 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Thanks konigstiger, I find the audio simply amazing.... Thanks for the detailed info! Sound can be so subjective also. I find music I have downloaded on my IPhone connected via Bluetooth simply amazing sound. My entire life, I set the EQ wave as a U. High Treble, Mid Midrange and High Base...... Just the way I like it!
