2015 - S550 Auto High Beams
1 Post
2019 G63
A friend owns a 2015 S550. The manual refers to Automatic High Beams and when you press the turn signal lever forward, an icon lights in the instrument cluster, indicating the auto function is active. Problem is, the high beams NEVER come on. The dealer, first tried to convince my friend the feature was an option he did not purchase. Then said, it wasn't an option, just not a feature and the only way to have your high beams on is, "Take the headlight switch from Auto to On, then move the turn signal indicator forward," and the high beams, do indeed stay on. Of course, when you pull into your garage the lights continue to stay on since no longer in Auto mode! Ridiculous, I say the function is in the vehicle, but broken!
Why would the instrument cluster have an icon that lights up indicating automatic high beams if not an active feature of the vehicle? Further, if not a feature then why wouldn't high beams simply go on with the headlight control in Auto, when moving the turn signal lever forward, as in every older Mercedes such as my 2008 S63 and even my 2013 G63?
Question for other owners of an 2015 S550 in the US. Does your vehicle have working automatic high beams or do you have to turn the switch from Auto to On to have high beams?
Thank you in advance to any who can respond!
2011 E550
I've driven my uncles 2017 S class for a week or so and you did have to set the light switch to auto, with the indicator stalk foreword to enable the auto high beam function. The high beams only came on during long stretches of open, dark road lmao, Never during basic city driving.
Same thing with my 2014 CLS550, switch on auto, stick forward.
2015 S550 Palladium/Deep Sea Blue, 2016 Tesla Model S 70D, 2015 Volvo XC70
For city driving, if you want high beams put on manual. When you park and turn off ignition the lights go out. On auto mode the highs only come on pushing turn signal stalk forward.
Why do people need to drive around with high beams on though? It does nothing but blind oncoming traffic, the extra light is thrown up and away from the road. I can see if you are out on the open road by yourself at night, but in any other situation, the normal headlights should work just fine if they are aimed correctly and clean. If you're having that much difficulty seeing at night, perhaps an eye exam is in order.
Personal pet peeve, I hate being blinded by idiots in oncoming traffic with high beams on.
Yes they work perfectly in my 2015 S550. It's on auto mode and stalk pushed forward. I don't have the complaints others here do. They come on when needed and automatically turn off when oncoming traffic is detected.
Sounds like they're broken somehow in this case. Can't imagine dealer can't diagnose this really easily.
Super Moderator
Received 3,171 Likes
These always-on hi-beam headlights is what the rest of the world can get, in the US we get the dumbed down headlights that selectively enable the high-beam function. Poor mans approach... Also very misleading as the manufacturers don't change the names of the lighting systems. The US intelligent lighting isn't very intelligent
2019 S560, 2022 Audi S8
I remember an old lincoln town car having this option back 25+ years ago, and you could adjust it and it worked great. It's an open on lower model Mercedes, like the new E class loaner I had, didn't have it, and it drove me nuts. It's a must, especially if you live on twisty roads to get home, etc.
My 2015 Auto Dim works fine. I notice if I want it to go to high beam a little quicker , I push the stalk towards the dash slightly and it usually goes to High Beam
Not sure where you're driving or how fast, but auto high beam doesn't work below 25 mph. Also it will not work when following another car -- it's that sensitive that it can pick up taillights. I've also had it switch back to low beams when I'm passing a yellow warning sign on the road due to reflection.
