S-Class (W222) 2014-2020
I want to lower my car, anyone has experience with Amazon OBD-2 module?
Old 08-30-2018, 07:57 PM
ALEXXMERS's Avatar
S63 AMG (C217)
Anyone here with feedback on the Amazon OBD-2 suspension module?
Amazon Amazon
Old 08-30-2018, 08:27 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
The problem with lowering this car is that you risk damage to the air struts as you are basically fooling the system into thinking the car is higher than it really is. You can do lots of very expensive damage to your suspension with a few hard hits of a pothole or bump. Ride quality will also likely suffer. It's not a honda civic, it is going to look odd to be slammed to the ground, and not in a good way.
Old 08-31-2018, 08:51 AM
merc.man's Avatar
2014 S550 4MATIC
Originally Posted by ALEXXMERS
Anyone here with feedback on the Amazon OBD-2 suspension module? https://www.amazon.com/dp/B07C7G3J13
My friend recently purchased that for his 2018 E63S Sedan, the car does not become "slammed to the ground like a Honda Civic" like some people say..it merely lowers the car 32mm or 1.25", the car rides just as well as before and even handles a little nicer, on his stock wheels it is a very clean look after getting rid of some of the wheel gap. You simply use the COMAND display and rotary dial to control how low you want the car, you can customize it to your taste up to 32mm (which is plenty for these big boats) I will be purchasing the module for my 2014 S550 4MATIC soon as well.
Old 08-31-2018, 01:58 PM
Super Moderator
Wolfman's Avatar
Received 3,171 Likes on 1,977 Posts
I am using a similar module (not Amazon but same setup) on our 2018 E63s. Renntech also makes these on the newer Airmatics via ODBII. They work well but don't raise at speed like previous modules, so an alignment is advised...
Old 08-31-2018, 02:14 PM
Quadrobenz's Avatar
'94 SL600,'05 SL600,'06 S65,'07 E63,'14 E63S,'09SL600 all sold, ‘15 S65,‘18 E63S,'17 SL65, '17S65Cab
Check out the thread on this subject running in the W222 S63 forum.
Old 08-31-2018, 05:45 PM
ALEXXMERS's Avatar
S63 AMG (C217)
wow, read all that I found on the topic and decided that this is really the most suitable for me option to buy this Amazon OBD module
Old 10-05-2018, 01:45 AM
prodrive's Avatar
I just use adjustable lowering link only
Old 10-16-2018, 01:30 PM
ALEXXMERS's Avatar
S63 AMG (C217)
Thumbs up
Originally Posted by Roman Morel
Got it?
Yeah, I received my module and it is very cool. very easy to install and all works as described
Old 11-06-2018, 09:22 AM
ALEXXMERS's Avatar
S63 AMG (C217)
I use not standard setting 'low' , i lowered my car for 45mm front and 40mm rear
Old 11-06-2018, 01:15 PM
raja777m's Avatar
2014 E350 4M Diamond Silver
before and after pics please. Thanks.
Old 11-06-2018, 01:54 PM
ALEXXMERS's Avatar
S63 AMG (C217)
lowering module S63
BEFORE
AFTER 1
AFTER 2
Old 11-06-2018, 02:08 PM
raja777m's Avatar
BEFORE
AFTER 1
AFTER 2
Damn that looks sexy. I believe the roads in your city are nice and smooth. IMO, the OEM height is not too bad at all.
The following 2 users liked this post by raja777m:
Mason.Safari (08-16-2023), W222_Bob (02-15-2019)
Old 11-06-2018, 02:47 PM
1bad540's Avatar
s550 Diamond white amg pano
looked pretty sweet stock, I hope your not driving around on the air shocks that low.
Old 11-21-2018, 04:52 AM
legendary's Avatar
2008 CL550, 2018 E400 Coupe, 2019 AMG GLE43 Coupe, 1968 C10 Restomod
Does anyone know if it’s VIN locked, like Renntech?
Old 11-21-2018, 06:28 PM
ALEXXMERS's Avatar
S63 AMG (C217)
yes, of course .
Roman Morel (11-22-2018)
Old 12-29-2018, 01:39 AM
badbenzz's Avatar
AMG GTS, Ford Raptor and Tesla Model 3 dual motor
Are you able to turn without rubbing
Old 12-30-2018, 07:17 PM
MBS63AMG's Avatar
2019 S560, 2022 Audi S8
Please don't do this! Yes , it might look good and cool and all, but you are going to mess up a perfectly good car.
Old 12-31-2018, 04:44 AM
Venom-AMG's Avatar
21 G63, 21 GLS580, 16 GTS Ed. 1
I just asked the seller and he said this is only for 4matic. MBC isnt compatible...... sucks, I wanted one. Any recommendations for lowering links in los angeles area?
Old 12-31-2018, 08:24 PM
badbenzz's Avatar
Go see Sam or Golan at Autotalent in Torrance, CA
Old 01-01-2019, 12:55 AM
Venom-AMG's Avatar
thanks, will check them out next week. They down the street
Old 01-03-2019, 01:55 PM
ALEXXMERS's Avatar
S63 AMG (C217)
you can look photosof my car on the top iam using it and it looks awesome!
Old 01-03-2019, 09:12 PM
badbenzz's Avatar
No one is questioning the look, the question is it bad for the car's suspension?
Drjim (07-16-2023)
Old 01-04-2019, 04:57 PM
ALEXXMERS's Avatar
S63 AMG (C217)
I can not say for sure, but I have no problems yet.
the only thought that the pressure in the suspension more and feel stiffness on uneven roads
Old 01-05-2019, 01:53 PM
Super Moderator
Wolfman's Avatar
yes, of course .
Aren't the Amazon modules made by the same guys as the Ebay module (located somewhere in eastern Europe)? If so, they would not be VIN locked. I only know of the Renntech module being VIN locked.
Old 01-05-2019, 02:03 PM
Super Moderator
Wolfman's Avatar
I use a similar module and really like. But if you ride that low, you will stress the struts and they can blow out when hitting a pothole as the air pressure is higher with less travel in the air chamber.
I don't don't know this module modifies the ride height. Previous ELM's or links spoofed the system it is at stock height. I don't know if this one simply modifies the values. If so, it would be recorded/logged.
That said, it's a question of taste. I think -32mm F/R would look great on your car
Quick Reply: I want to lower my car, anyone has experience with Amazon OBD-2 module?
