No Start, all looks OK but wont crank
I have a W222 2015
Today I went to start it and it does not crank, does not click, dash lights do not dim. Key moves all the way as it should I checked in Xentry, all relevant units have DAS Start authorization All circuits are on except circuit 50 (ignition). When I turn the key to crank, circuit 50 jumps to ON Xentry is zhowing zero errors. Would appreciate any advice to help pinpoint, I switched out the starter relay, made no difference. I have the wiring diagrams, all fuses seem OK. |
Based on what you said if its possible I think I would be inclined to try to run jumper wires to the starter and see if it works......
SOLVED
Have solved it.
Found another fuse. Initially I checked Fuse 111 which runs to the starter solenoid. Then I checked the circuit diagram and found another fuse (129) which is just before the starter relay, turns out that was the culprit Fuse diagram attached, hope this helps someone in future https://cimg4.ibsrv.net/gimg/www.mbw...cd7ea13f63.jpg |
Good to hear you got it fixed , I thought it was a battery related issue
Happy Driving |
