Go Back  MBWorld.org Forums > Mercedes-Benz Sedans > New S-Class (W222)
20 inch wheel setup for 4matc >
New S-Class (W222) 2014-Present
Old 02-19-2019, 05:06 PM
STAGGERED SEDAN's Avatar
Liked 0 Times in 0 Posts
2015 s550 4matic
Whatís up folks just had a question,what 20 inch tire size is safe to use that wonít affect my 4 matic and cause problems that can damage components or possibly destroy my diff ,I ran the oem 20 inch wheels with the fronts being 8.5 wide with a 255 40 20 tire and rear with a 9.5 wide wheel with 285 35 20 tire but I noticed irregular clunking on turns ,any info will be helpful thanks
STAGGERED SEDAN is offline
Old 02-19-2019, 05:43 PM
Liked 9 Times in 8 Posts
On the hunt
It's recommended that you don't stagger a 4-Matic... it's a square setup... All 4 are equal in width and size.
20" x 8.5" is the stock OEM MB 20" wheel size.
W222_Bob is offline
Old 02-19-2019, 06:09 PM
2015 s550 4matic
Ok good to know I need 2 8.5 wheels for the rear then also ,what tire size do you recommend ?
Old 02-19-2019, 09:48 PM
Liked 72 Times in 64 Posts
2014 S550 AMG, 2017 XT5
Not so, car is sold with Staggered setups also with 4-Matic
Nice Ride is offline
Old 02-19-2019, 10:09 PM
MA6226's Avatar
2010 E350 4matic
I put 20s on my 2010 w212 4matic , no rubbing semi staggered.
MA6226 is offline
Old 02-20-2019, 05:09 AM
2015 s550 4matic
Ok whatís your wheel widths and tire sizes ,just need to know whatís safe for the vehicle
Old 02-20-2019, 08:25 AM
MA6226's Avatar
2010 E350 4matic
fronts are 245/35/20 rears 275/30/20
MA6226 is offline
Old 02-20-2019, 08:44 AM
e55phil's Avatar
Liked 10 Times in 9 Posts
2019 e63 s wagon on order, 2015 s550, 1979 240d, 2002 e55, 2001e55, 1971 300sel 6.3
I own a set of 20 inch wheels that are staggered that came with the car. I had four flats in the first two years because we have so many potholes in New York. I took the tires off and bought a set of 19 inch wheels and haven't had any problems since that time. I'm thinking about moving my 222 to Florida and I might put the 20 inch staggered wheels back on the car just because in Florida there don't seem to be any potholes
e55phil is offline
Old 02-20-2019, 08:47 AM
MA6226's Avatar
2010 E350 4matic
Born and Raised in Brooklyn , got on the job then moved to Long Island ... NY killed my 85 C10 dropped and my Silverado on 24s . Been here in Florida 11 years , roads are great . This is my first w212 and would never get another car , but love nice rims !
MA6226 is offline
Old 02-20-2019, 09:20 AM
2015 s550 4matic
I seen some links that say the 2014 and up w222 4matic does offer a 20 inch wheel option for the standard and sport 4matic with tires 245 40 20 and 275 35 20 ,I want to go this route to prevent the clunking noise ,Iím just not sure if these links are accurate ,does anybody know an accurate link that contains the correct info ?
Old 02-20-2019, 09:40 AM
rustybear3's Avatar
Liked 90 Times in 81 Posts
2019 Dune Silver Metallic E-450 Mercedes Cabriolet
I don't know where you live, but if it's a Northern climate with potholes avoid 20's like the plague. I'd stick with 19's as a safer bet for ride quality, less chance of wheel fracturing or breakage, and of course tire blowouts. Just my 2 cents.
rustybear3 is online now
Old 02-20-2019, 01:02 PM
1bad540's Avatar
Liked 105 Times in 99 Posts
s550 Diamond white amg pano
seems correct, I have that size on my car and its fine.
1bad540 is offline
Old 02-20-2019, 01:25 PM
2015 s550 4matic
so you have 4 matic and you have no issues even on full turn ins and outs ?
Old 02-20-2019, 01:26 PM
MA6226's Avatar
2010 E350 4matic
the 20s , I have on now . I have to rubbing or anything
MA6226 is offline
Old 02-20-2019, 01:51 PM
1bad540's Avatar
no problems at all... just use the factory size.
1bad540 is offline
Old 02-20-2019, 02:31 PM
2015 s550 4matic
my issue wasnít rubbing it was what they called scrubbing of the front wheels on full turns or a clunking sound sort of sounding like a bad cv joint but it was due to the staggered fitment of the wheels and tires I had on the car ,the problem only pertains to the 4matic vehicles ,I want to avoid destroying my diff
Old 02-21-2019, 10:44 AM
Liked 84 Times in 75 Posts
2015 S550 4Matic
You can run staggered rims and tires on a 4matic car. My MY15 S550 came from the factory with staggered 19" AMG rims. The critical thing to remember is the rolling diameter of the tires needs to be within 3% front to back. You cannot run larger diameter tires in the rear like you might with an SL or other 2 wheel drive car.
superpop is offline
Old 02-21-2019, 10:50 AM
2015 s550 4matic
On the 19ís you have what are the tire spec sizes for the front and rear ,and what are the rim widths for the front and rear
Old 02-21-2019, 03:17 PM
1bad540's Avatar
your issue is not the 20" wheels its that your not running the correct size tires. They need to be within 3% rolling diameter of ea other. All the newer s classes leave the factory w factory staggered wheels.
1bad540 is offline
Old 02-21-2019, 05:16 PM
2015 s550 4matic
yea I looked up the specs and from the factory they run 245 40 20 for the fronts and 275 35 20 for the rears ,Iím going to go with that
Old 02-24-2019, 02:03 AM
badbenzz's Avatar
Liked 13 Times in 11 Posts
CLK63bs, E550,500E(Fiat),C55,VROD
Make sure the diameter of the front and rear tires do not exceed .02
badbenzz is offline
Quick Reply: 20 inch wheel setup for 4matc
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
