W222 Wheel nut socket
Getting close to that time to put new shoes on my S 350d w222. The car came with continental contact sport 2, rear need replacing after 13k miles still about 1500 - 2000 miles left on the front.
Think i'm gonna try michelin pilot sport 4s this time, any recommendations much appreciated.
Now onto my question I've read conflicting reports about what socket to use to remove the lug nuts, some say a standard 17mm is fine others say this will damage the nut. I called my local dealer ship they told there is a special socket which they dont sell and dont know where to source it... most helpful
I found this online ... looks about right, but its only listed for c & e classes...
https://www.lasertools.co.uk/product/6247
2016 S550 sport, 2018 GLC300, M3, Zo7, 2021 Sierra Denali
That Sunex is a nice socket and fits perfectly. But I have a nylon coated 17mm rug socket from my other German cars and it works perfectly. Its a stainless steel cap and doesn't look damaged from the 17mm to me. If you buy the sunex I would wrap a single layer of duct tape on the outside to protect the rim...which is why I use the specific nylon coated lug socket. Sometimes you spin off and touch the rim.
Oh, I just noticed your link is what I am talking about having the coating to protect the rim. Thats it!!
This topic had me buy this one today: Free shipping
https://www.ebay.com/itm/Protective-...72.m2749.l2649
2019 S560, 2022 Audi S8
17mm will work. I use BF Goodrich tires. I keep 50 pounds in all 4 tires all the time. I get 30,000+ miles on a set . I have staggered wheels. I now have 64,000 miles on my car. Car drives and feels great. Less pressure equals less miles. I keep 50 pounds in each tire of my Honda Goldwing and I get 15, 000 + miles on each pair of tires. My friends get less than 8,000. Why they don't take my advice is beyond me. Been doing this for 20+ years.
Is that Cold Pressure?
I usually run 5 over recommended.
I just looked at the sidewall of my Conti 5P tires. The Max cold inflation pressure is 51PSI. MB recommends 39/39 up to 155MPH, 49/51 up to 186MPH, all with full rated load in the car. I use 45/39 for normal use, 2 passengers. That is above the MB recommended pressures for light loads.
Max tire pressure on the tire means nothing as related to the car. The recommended tire pressures loaded and for speed are all that should be used as recommended by MB. That is if you are using the OEM tire when those recommendations were made and tested. If you switch brands then you have to follow the brands recommendation. This is how Ford had all the blowout issues with the explorer years ago. The difference was manufacture recommended and then tire brand recommended PSI.....they were wrong and lawsuits ensued after many deaths.
Not having the best time with my sclass for sure, posted already here about moisture in both headlights waiting for a gel pack install later this month.
Today I finally got around to getting two new rear tyres fitted, only to find they marked both alloys, take a look on here:
https://alloydamage.blogspot.com/201...arch-2019.html
Not a good day for sure, naturally the manager started with "we noticed some marks before we started our work"..... which is total nonsense as both rims were mark free.
Luckily I took detailed photos prior to letting them work on it so now starts the blame game.
I leave nothing to chance when having tires dismounted. I ask for an inspection and agreement of condition prior. I did have a mark once and the tech stopped in his tracks before dismounting the tire and came right out and told me to look at it before he started. I'd call bulls##t on your guy.
So hard to find a competent tire shop. With all the fancy rims and low profile tires along with rubber band runflats I am still shocked at how few a shops there are that have the right equipment and skilled techs to keep up with todays cars. Most of the shops have 1980's tire machines! Like they are working on steel rims these day??? Yes, but not many.
So Im not alone with this issue, pre-inspection a must for me no matter what work Im having done in future.
was gonna ask for it this time but this particular company came highly recommend so I didnt do it.... kicking myself now but at least I have photos.
Cheers for the reply Seamus, you must have a connection with the emerald isle with a name like that? Im a paddy too
Yes Sir, first generation born here, family from county Clare, actually going over in July for my first trip to Ireland! Really looking forward to it. Be well my friend and good luck with the repair.
