S-Class (W222) 2014-2020
222 s550 Rotor "Handle with Care?"
Old 04-12-2019, 10:31 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Exclamation 222 s550 Rotor "Handle with Care?"
Found this note for Rear Rotors:
This Part Fits Your 2014 Mercedes S550 4Matic.
  1. Rear ~ NEW STYLE BRAKE DISC WITH THIN HIGH TENSILE SHEET STEEL HUB. HANDLE WITH CARE! DO NOT PICK UP AT THE HUB. FOLLOW INCLUDED INSTALLATION INSTRUCTIONS. w/ Sport Package Code 951
Can someone explain what they mean "Do Not Pick Up at the Hub?"
Genuine Mercedes Disc Brake Rotor; Rear
P/N: 2224200672 Genuine MercedesCross References:
  1. 222420067228
    • 2224231400
Mercedes S550
https://www.autohausaz.com/pn/2224200672
Also, are these the OEM TPMS Sensors? On average, how long do the Sensor(s) / Batteries last? I plan on getting rims re-finished and figured while the Tires are off to replace them. Car Purchased 1/2014
Schrader Tire Pressure Monitoring System (TPMS) Sensor; 433MHz
P/N: SR-0009050030 SchraderCross Referencehttps://www.autohausaz.com/pn/SR-0009050030
Old 04-13-2019, 08:45 AM
1bad540's Avatar
s550 Diamond white amg pano
U should be good w the sensors they last years. I know where u can get a new set for like 50 if you need...didnt the set from me have them also?
Old 04-13-2019, 12:35 PM
Mitch Alsup's Avatar
S600
They want you to pick it up with both hands on the outer parts of the rotor (covered in latex/nitrile so as to not contaminate the rotor) and not pick it up by the floating hub.
Old 04-13-2019, 08:36 PM
Nice Ride's Avatar
Yes. I have my original Rims being sent out and new set of Shoes on them. Detroit Wheel and tire has best pricing, but they farm out 90% of the work. The Black Chrome PVD is a little darker than I would like, so I'm going to give AmericanPVD a try. They do all the work inhouse. The Onyx color is closer to what I am looking for. I know you mentioned Al's for mounting tires. 1800 50 Tires in Valley Stream did damage to several rims, not to mention the workers have no idea how to use the Hunter machine nor what a torque wrench is. I don't mind paying a bit extra for my OCD.
Old 04-13-2019, 08:38 PM
Nice Ride's Avatar
Only the AMG Ceramic Rotors have a floating hub. The S550 is all one piece design....
Old 04-14-2019, 01:40 PM
S600
The note OP got with his rotors stated "a high tensile strength hub." SInce the rotors are not of a high tensile strength material, the hub and rotor are separate pieces.
Quick Reply: 222 s550 Rotor "Handle with Care?"
