Other Cars Discussion of non Mercedes Benz vehicles
Battery charge light will not turn off
Old May 25, 2021 | 08:12 AM
Kolusion's Avatar
Honda Prelude Si 4WS
Question Battery charge light will not turn off
I am having really big trouble with my 1991 Honda Prelude and it's getting to the point where I am starting to feel like I want to get it towed to the wreckers. I don't really want to do that but it's really taking the cake.
I hosed down my engine bay and the battery warning light came on and then an hour later my battery went flat. So far, this is what I have done to try and fix the problem:
- Checked the alternator fuses
- Fully charged the battery
- Replaced the alternator with a remanufactured unit
- Replaced the crankshaft pulley
- Replaced the drive belt
Today I checked the replacement alternators' B terminal with a multimeter and it's reporting just 3.84 volts! I thought perhaps the belt was slipping so I tightened it but it made no difference.
The only thing that I haven't checked is the air conditioner compressor pulley.
This could be a hint but it could also mean nothing... when I first installed the replacement alternator, the battery charge light no longer came on but the drive belt was squealing really loud. Then half an hour later, the squealing stopped and the battery charge light came back on again and has been on ever since.
What do others think?
Old May 26, 2021 | 05:54 AM
Kolusion's Avatar
Today I used a multimeter to perform tests on the alternator. I hope someone can tell me why the alternator is putting out 3.88 volts only.
All tests were carried out with the engine running at 800 RPM except for the last rectifier test, and the battery cable was disconnected from B terminal.
B terminal with alternator connector connected:
3.88 volts between B terminal and engine
3.89 volts between B terminal and battery negative post
-7.9 volts between B terminal and battery positive post
6.8 millivolts between alternator housing and battery negative post
B terminal with alternator connector disconnected:
0.93 volts between B terminal and engine
0.94 volts between B terminal and battery negative post
-9.74 volts between B terminal and battery positive post
0.64 millivolts between alternator housing and battery negative post
Alternator terminals (grounded to engine/grounded to battery negative post):
IG: Nil/6.2 volts
S: 3 volts/3 volts
L: Nil/6.4 volts
FR: Nil/6 volts
Alternator connector (grounded to engine/grounded to battery negative post):
IG: 11.5/11.52 volts
S: 4.58 volts/4.58 volts
L: 11.49/11.5 volts
FR: 11.81/11.82 volts
Alternator rectifier test with engine running:
Multimeter positive probe to B terminal/Multimeter negative probe to alternator housing: Nil
Multimeter negative probe to B terminal/Multimeter positive probe to alternator housing: -240 millivolts
Alternator rectifier test without engine running:
Multimeter negative probe to B terminal/Multimeter positive probe to alternator housing: -933 millivolts
Old May 26, 2021 | 07:46 AM
Kolusion's Avatar
Is it just me or do others also see a grounding issue with either the alternator or the engine?
Old May 27, 2021 | 02:42 AM
Kolusion's Avatar
I just tested the voltage between the following:
Battery positive terminal and battery negative terminal
Battery positive terminal and engine
Battery positive terminal and alternator
All results matched, so the problem can't be bad grounding.
Does anyone know what else could be the problem?
Old May 27, 2021 | 07:27 AM
ygmn's Avatar
2015 E400 Sedan
Try a HONDA forum
Old May 27, 2021 | 08:10 AM
Kolusion's Avatar
O. What's wrong with this forum?
Old May 27, 2021 | 11:02 AM
Kolusion's Avatar
I think I may have found a clue. S should be 12 volts, have a look at S in the charging system circuit diagram.
http://media.honda.co.uk/car/owner/m...f100/16-66.pdf
Now have a look at my test results of the alternator connector.
IG: 11.5 volts/11.52 volts
L: 11.49 volts/11.5 volts
FR: 11.81 volts/11.82 volts
S isn't even hitting 6 volts, so there is resistance either in the wiring or the fuse. Does anyone know if this is of significance?
Old May 28, 2021 | 04:07 AM
Kolusion's Avatar
So the diagrams in the shop manual for the alternator terminals and the alternator connector are pretty crap and I thought the diagrams were of the alternator terminals but they are actually of the terminals in the alternator connector. I realised when the result I was getting on the multimeter from S at the under-hood fuse box wasn't corresponding with the result I got yesterday from S on the alternator connector. These are the correct test results from yesterday of the alternator terminals and alternator connector.
L: Nil/6.2 volts
FR: 3 volts/3 volts
IG: Nil/6.4 volts
S: Nil/6 volts
L: 11.5/11.52 volts
FR: 4.58 volts/4.58 volts
IG: 11.49/11.5 volts
S: 11.81/11.82 volts
I don't know if the FR circuit to the ECU is 12 volts, but if it is then there appears to be a problem somewhere in the FR circuit.
To rule out the FR terminal in the alternator connector being bad, I followed it's WHT/RED wire to it's socket at the top right hand side of the engine bay, disconnected the connector that connects to the socket and then tested the FR terminal inside the connector.
https://i.ibb.co/0Y1ShrJ/FR-at-top-r...-connector.png
These are the results:
FR at alternator connector: 4.55 volts
FR at top right hand side engine bay connector: 4.94 volts
Old May 29, 2021 | 05:07 AM
Kolusion's Avatar
Never mind, I the FR voltage is fine.
I can now confirm the car is good and the alternator is ****ed. The place I got it from is sending out another one to me.
