Parting Out Parting out threads by members.
WTB: W210 ROCKER COVER/SIDE SKIRTS SILVER
Old Oct 11, 2008 | 02:06 AM
youngblood's Avatar
There are actually TWO catches, one in each of two recesses that can be found, respectively, at the front lower left and front lower right of the rear seat, just follow your hand around the line where the seat meets the support and as you move around the front lower corners you'll feel the recesses. Put your finger in there and you'll feel a little plastic lever, lift up on it and then lift up on the seat corner. Do the same on the other side, then pivot the seat up and remove it. When you put it back in just check to be sure you have the seat belts all clear.
Old Nov 29, 2008 | 07:42 PM
Lowflyingbird's Avatar
E300DT
Side skirts in silver
Hi,
Are you still looking for these? I might be able to help you out.
Please reply, better email me directly ksilibovsky@hotmail.com
Lowflyingbird
