Best you can do for your car!
Like I allways sad about K-jet...Yeah just send it to sibirijan!
Mercedes engines has allways been very high performans parts with very high quality and it make me cry why they choose K-jet for so long time! If you realy love your car and stil have a K-jet, make very big differnce for your engine character and prosperous and it doesn not take many days to fix it if you have a good support. Last week example: Mercedes benz 300CE-24. Standalone system instaling. Megasquirt MS1-extra with stock dizzy ignition this time. Parts we need: Megasquirt ECU configuring for VR sensor and Distributor ignition. (can even choose wasted spark and coil on plug) Harness 2pcs relay Fuel rail Fuel fittings Fuel regulator 6 of 250cc injectors triggewheel 36-1 VR sensor vr sensor fitting TPS sensor CLT sensor IAT sensor Air filter Simple ignition coil (mercedes coil is too low ohm for the ecu) http://archive.pixbox.se/arkivet/syn...0/18493582.jpg We start to replace the stock damper to triggerwheel 36-1 and fit the VR sensor http://d4126198.u72.surftown.se/imag...aretrigger.JPG Then its time to take some hand with K-jet...yeah .. http://d4126198.u72.surftown.se/images/kjet01.JPG gone.... http://d4126198.u72.surftown.se/images/kjet02.JPG http://d4126198.u72.surftown.se/images/kjet03.JPG Making the fuelrail http://d4126198.u72.surftown.se/images/mattareil1.JPG http://d4126198.u72.surftown.se/images/raili10.JPG http://archive.pixbox.se/arkivet/syn...0/17568058.jpg http://archive.pixbox.se/arkivet/syn...0/17568059.jpg |
Then make some fuelfittings to fit them the stock fittings and Fuel regulator
http://archive.pixbox.se/arkivet/syn...0/18099367.jpg http://archive.pixbox.se/arkivet/syn...0/17568060.jpg Then fix a little with throttel house to fit it with aftermarket TPS sensor http://archive.pixbox.se/arkivet/syn...0/17568061.jpg http://archive.pixbox.se/arkivet/syn...0/17568062.jpg http://archive.pixbox.se/arkivet/syn...5/17622847.jpg http://archive.pixbox.se/arkivet/syn...5/17622848.jpg The plate for a wire.. http://archive.pixbox.se/arkivet/syn...5/17622852.jpg Airfilter pipe with IAT sensor and CLT sensor in the water pump http://archive.pixbox.se/arkivet/syn...5/17622849.jpg ECU http://archive.pixbox.se/arkivet/syn...0/17645995.jpg |
New harness
http://archive.pixbox.se/arkivet/syn...0/17645996.jpg http://archive.pixbox.se/arkivet/syn...0/17645998.jpg Robert supercharger 6,9 and me... http://archive.pixbox.se/arkivet/syn...0/17645999.jpg http://archive11.pixbox.se/arkivet/s...0/17666843.jpg Trying go online http://archive.pixbox.se/arkivet/syn...0/17698811.jpg http://archive.pixbox.se/arkivet/syn...0/17723659.jpg And the first start. Left to do is to fix the cables and mapping! YouTube - MB 300-24v Megasquirt first start |
Next one tired of K-jet and came to us today!
300CE-24v http://archive.pixbox.se/arkivet/syn...0/18321405.jpg http://archive.pixbox.se/arkivet/syn...0/18321407.jpg Time to take some things away http://archive.pixbox.se/arkivet/syn...0/18321408.jpg http://archive.pixbox.se/arkivet/syn...0/18321409.jpg Some new stuff http://archive.pixbox.se/arkivet/syn...0/18321411.jpg This time we use different trigger by making 3 holes with M6 thread in the crankdamper och use 3 bolt as a triggerteeth. 120 degree between each bolt 4mm high aluminum distans and 4mm bolthead makes 8mm triggerpoints. http://archive.pixbox.se/arkivet/syn...0/18301256.jpg http://archive.pixbox.se/arkivet/syn...0/18246192.jpg http://archive.pixbox.se/arkivet/syn...0/18301257.jpg http://archive.pixbox.se/arkivet/syn...0/18301258.jpg Hall sensor and bolton fitting http://archive.pixbox.se/arkivet/syn...0/18290122.jpg |
Today was out of weldgas and cable but some things been done anyway.
http://archive.pixbox.se/arkivet/syn...0/18420399.jpg Fitting to IAT http://archive.pixbox.se/arkivet/syn...0/18420402.jpg Making a thread http://archive.pixbox.se/arkivet/syn...0/18420403.jpg http://archive.pixbox.se/arkivet/syn...0/18420404.jpg out of gas before finishing this pipe... http://archive.pixbox.se/arkivet/syn...0/18420400.jpg http://archive.pixbox.se/arkivet/syn...0/18420401.jpg |
wireplate
http://archive.pixbox.se/arkivet/syn...0/18470508.jpg airfilterpipe with IAT http://archive.pixbox.se/arkivet/syn...0/18470479.jpg Robban plays with cables http://archive.pixbox.se/arkivet/syn...0/18470476.jpg Allmost done, just fix some cables... http://archive.pixbox.se/arkivet/syn...0/18470477.jpg http://archive.pixbox.se/arkivet/syn...0/18470475.jpg First start YouTube - Megasquirt first start (mercedes instal 3) |
So the MS system is an upgrade over the stock k-jets huh?
it looks as though you do good work:y
Originally Posted by bumpnzx3
(Post 2666633)
Nice job!! You guys ever think about using Autronic?
are there any actual HP / TQ gains by doing this mod? whats the cost? ... this could be awesome when going forced induction!
Originally Posted by OJwerks
(Post 2725200)
Most 24V are the M104-24V which uses HFM full electronic ingnition. |
