Questions about how MBWorld.org works...not for car questions. Use this forum for help on using all or any part of the forums. Make sure to read the Forum FAQs first.
1994 sl500 giving problem runing after it is hot
Old Nov 30, 2011 | 06:01 PM
cjvibug's Avatar
(1994 sl500) and (2007 c230)
I have a 1994 sl500 that will starts and run great at first when its sit for a while. After running for a little its start sputtering and once I turn it off it will not start. I have change the crank position sensor, the fuel filter, the air filter, the air filter and the fuel pressure regulator and the car is still doing the same thing. Any more suggestions?
Old Dec 1, 2011 | 01:34 AM
Mslaughter's Avatar
Brilliant Silver CLK 320
Are there any codes? MAF possibly?
Old Dec 1, 2011 | 02:52 PM
cjvibug's Avatar
No, there is no code. It would start good and run like a champ, which tells me that it can’t not to serious. I use to be able to wait like 5 minutes and start it but now it takes a lot longer which after reading most on the trends I decided to do all of those things.
