Front grille removal
1 Post
02ML320/06R350
I cannot find it in my Star DVD on how to remove these 2 front grille at the bottom bumper. I`ll be putting a TM tuning LED lights on these areas and before I break these tabs P L E A S E share your thoughts on how to remove it. Thanks in advance.
Front lower panel removal
I just installed LED lights on mine. I took out the lower sections where they are normally installed. The is one screw holding the entire section. You have to bring them inside where it's warm. I let them warm up and then you simply push the tabs towards the center while pushing down. Once that tab has moved down go to the next one and work your way around then push on the center and the black section will release.
Mercedes Benz S 550
