2006 R-Class start but stalls directly
Hi, My R-Class 350 2006, starts but shut of directly, is there somebody who can tell me where to look?
I figured out that it had to do with the 2 green relay's if I change them from the spots the car will run and I can drive, but when I shut down the car I can't start the car again, and need to switch those relay's again to let the car run. |
Have you asked the service center about the crank sensor or the balance shaft issue that is a problem with the 2006 R350? check the threads on theses issues. hope this helps. Look under the M272 engine.
Bruce |
Originally Posted by Arie1st
(Post 5214457)
Hi, I had the same thought, and replaced them, but didn't had any luck.
still the same issue. But thanks for your suggestion |
I replaced the F58 Unit (10 min job) 4 wire connectors and 1 power wire ) now everything works normal again. (the F58 unit is the fuse and relay box under the hood)
:y
It is good to hear your R is working again. |
Hi - I am having similar problem and do not know what is the F58 unit. Is that the fuse number 58 and what relay did you replace?
thanks to Arie1st - I bought the fuse box via ebay and swapped it out. Deallership wants over $300 for it. Once received, I swapped it out and it works without stalling. :y
M
My 350 is stalling after swapping transmission and I swapped vgs board codes d139 and d13a any help
