R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Oil usage in an R350
Old Dec 26, 2014 | 03:38 PM
Epiphany's Avatar
R350
What is normal oil usage in an r350 with about 110000 miles?
Old Dec 26, 2014 | 04:02 PM
ghenry's Avatar
2008 R350, 2024 Subaru Legacy,2018 Chevy Colorado
My (350 gas engine)oil level stays at or near the full mark for 10000 mi. In that 10000 mi span I change filters 2-3 times @ $9 ea and never add oil.
Old Dec 27, 2014 | 06:44 PM
efzauner's Avatar
2005 C240 2011 R350
Change filters 2 times in 10,000 Miles? That seems way OCD excessive!
Manual says filter/oil @10,OOO miles.
Old Dec 27, 2014 | 06:56 PM
ghenry's Avatar
I am a little overboard on maintenance but.......retired , plenty of time so why not treat it well. Its been a very good vehicle . An excellent ride!! Hopefully it'll last for many years.
Last edited by ghenry; Dec 27, 2014 at 07:46 PM. Reason: Sent before finished typing
Old Dec 30, 2014 | 10:21 AM
efzauner's Avatar
2005 C240 2011 R350
for gas you should rarely need to top up
For diesel 1 -2 liters between oil changes is to be expected.
@ghenry...there is no reason to do this.... your time and money would be better spent elsewhere! Buy flowers for your wife and kiss her!
Old Dec 31, 2014 | 11:23 AM
gforaker's Avatar
2015 Audi S4, 1982 Fiat Spyder, 2010 R350, 2013 E550 Cabriolet
Exactly! The filters are designed to work at least as long as the oil, and usually longer.
Old Feb 3, 2015 | 12:22 AM
geniushanbiao's Avatar
2012 ML350 Bluetec, 2015 GL350 Bluetec
Well from the newest research this is not necessarily true. The oil technologies are renovating every day but filters don't improve once the engine is designed. Remember this M272 engine is introduced in 2004 so it was probably designed in the 19th century or around 2000. And the filter for M272 is the same as the one for M112 which was introduced in 1998, probably designed in mid 1990s.
Basically for most cars if synthetic oil is used then the oil can last at least 15-20k miles(some veterans says military vehicles use oil even longer than this) but filters don't last that long especially if vehicle is mostly driven in city.
Old Feb 3, 2015 | 11:23 AM
gforaker's Avatar
I'd like to see your sources for this "new research". That might be true for diesel engines, but I don't think gas engines from MB should have that much particulate and dirt in the oil to clog a filter.
