Sensor B bank 1, which side is that
Hi, I'm yet again having trouble with my 2006 R350.
It is never ending, I've never owned a car that has so many failures. I now have these faults: P0013- Camshaft position actuator B - bank 1 circuit malfunction. P0017- Cam/Crankshaft Pos. Correlation sensor B - bank 1. P2189- Sys too lean at idle - bank 2. P2187- Sys too lean at idle - bank 1. Which is bank 1/2? Same for sensor/actuator A/B. If anyone can help, it would be much appreciated. I'm guessing at the actuator magnet and sensor, but far from sure. It has had the whole super expensive timing chain and balancer replacement, as well as a new chain tensioner, but it still rattles at start. I'm about to give up on it and take it to the tip. I've also had front diff replaced due to failed bearings, rear air bags replaced due to leaks, CV joints replaced, AC module replaced, AC vent motors replaced, door lock motors replaced, MAP sensor replaced, headlight motor replaced, you get the idea.:nix::beatdeadh:wall: |
OK, I found out bank 1 is right side as sitting inside of car.
Or passenger side for the USA. (drivers side here in Australia) But which is sensor or actuator B? |
