R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
R500 A/C Issue
Old Aug 4, 2015 | 10:46 AM
FriscoMB's Avatar
R500
R500 A/C Issue
A/C never really cools off on driver's side. The passenger gets plenty cool, after a a little while.
First took the car to a certified mechanic, then to the dealership; both state that the heater box or heater core needs to be replaced.
Dealership quoted $6,600.00 for the repair. Ludicrous!
Has anyone else had this issue?
Old Aug 14, 2015 | 02:40 PM
vorozhbyt's Avatar
R-500 2006
Hi,
I had such an issue, and in my case it was cured by adding some freon to the A/C system. And it was dirt cheap :-)
Old Sep 7, 2015 | 08:58 PM
Cucucachu's Avatar
R500
My A/C is ice cold at start up (drops to 60F) and warms to 80F when the engine reaches normal operating temperature. Evaporator is creating condensation (i.e. getting cold). Connected a coolant servicing gauge, no R34a pressure leak. Believe I have a heater valve internal leak.
I hope I'm not looking at the same issue.
Old Oct 8, 2015 | 09:57 PM
Cucucachu's Avatar
R500
Found it is the expansion valve. Dealer explained most common A/C problem if not leaking will be the expansion valve. Looks like a pain to replace.
