R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
FS 2008 R320 DPf
Old Aug 4, 2018 | 09:25 AM
marc hanna's Avatar
2023 GLK250, 1987 560SL
FS 2008 R320 DPf
Hi all,
I’m performing a DPF delete on my ‘08 R320 CDI. Just looking to see if anyone is interested in buying my DPF. It’s fully functional.
Make me an offer.
marc
Old Aug 28, 2018 | 08:42 AM
marc hanna's Avatar
Well, she’s all deleted now. Another 10 - 15% improvement in fuel economy and some freed-up hp and torque.
I haven’t dyno’d it yet, but claims are generally about 250hp and 500ft-lbs.
In the end I was not particularly concerned with the performance gains, but rather the engine longevity and fuel economy.
I’ll keep everyone posted on fuel economy over the next little while.
The DPF is still available for anyone who’s interested.
Old Aug 28, 2018 | 08:49 PM
taranch's Avatar
BMW 340i xDrive 2018 MMPSK silver , Cadillac XT5 2018 silver, 09 R320 BT
Hi Mark,
Was it a big job? What's involved in removing it? Have you noticed any benefits in power/fuel consumption? Is it smoking very black now?
Cheers
Old Aug 28, 2018 | 09:03 PM
marc hanna's Avatar
It’s a simple job. I took it to a local shop though because I don’t have a hoist. Unbolt the DPF and bolt in the delete pipe. Make sure you reprogram it prior to taking the DPF out or it will throw a code when you start it up. They charged me an hour and a half, but they spent a while welding up a broken bracket.
No smoke even when wide open. It seems a little peppier, but that could just be wishful thinking. So far, I seem to gaining about 10% fuel economy, but I’ll have a better idea after a few tanks.
I used the CB engineering delete pipe, which is a new offering for them. Nice quality pipe with a bung for the forward-most sensor. The differential sensor lines are left disconnected. I used the GDE off-road tune. All in, it cost about $1,500 CAD.
Old Aug 29, 2018 | 07:12 PM
efzauner's Avatar
2005 C240 2011 R350
what about ontario smog testing? or is that 10 years only? just wondering
Old Aug 29, 2018 | 07:38 PM
marc hanna's Avatar
I’m no longer a resident of Ontario. In Nova Scotia we don’t have emissions testing.
Old Aug 29, 2018 | 08:36 PM
taranch's Avatar
Enjoy!
Old Jan 3, 2019 | 10:30 AM
Sierra Grande's Avatar
2008 R320 4MATIC
Hey Marc!
Any fuel mileage data yet? I am seriously considering this. Couldn't one use a (more) conventional oil with the DPF deleted? I have the GDE eco-tune and have been very satisfied.
Old Jan 3, 2019 | 06:37 PM
marc hanna's Avatar
It’s hard to make a direct comparison, on account of mixed driving conditions and different fuels. I have however gotten four of my five best tanks ever. I would estimate about a 5% to 10% improvement. I was able to maintain equivalent mileage runnng furnace oil as I was getting with diesel also. And here, our diesel and furnace oil are not the same fuel.
Old Jan 3, 2019 | 07:25 PM
2008 R320 4MATIC
It is tough without driving the same routes, speeds, same season, etc. I moved recently and have a new commute and need a few tanks to see. I didn't see a fuel increase with the GDE tune, but I think I just started driving faster. In Denver CO in mixed driving I got 21 mpg. That was what I saw average of many tanks on the same commute. Commuting from Colorado Springs to Denver (mostly highway) cruise set on 75 mph, I got 30 mpg. That was about the only good thing about that commute! My new commute is all city, so I expect to see a decrease.
Is your furnace oil kerosene? I know diesel, kerosene and jet are from the same family. I would be afraid to run anything in the Merc' not from the diesel pump!
Old Jan 3, 2019 | 10:13 PM
marc hanna's Avatar
No, kerosene is another grade yet. I treat the furnace oil with a lubricant, cetane improver and an injector cleaner, so it runs better. Usually for use in the tractors. Furnace oil is diesel #1, and is the next fraction that comes off after kerosene and has a lower freezing/gelling point than diesel #2. Diesel #2 is your standard summer grade diesel at the pump. #1 is also blended into diesel #2 for winter blends. When sold as furnace oil and not as diesel fuel, it does not have the additive packs blended in and therefore no specified cetane number or lubricity value, thus the need for additives. Generally speaking though, the price of furnace oil is not that much better, and after the cost of additives + lower energy content, you aren’t saving money, so it’s not really worth the effort or risk of getting fined.
BTW if you buy bulk fuel, it’s better to get diesel #2 for winter and then treat with an anti-gel. You’ll get much better fuel economy on account of the higher energy content. #1 blends, come at a cost in reduction in energy content without giving that great of an improvement in gelling point.
Basically kerosene, #1, and #2 will all run fine in any Diesel engine, but long-term can cause problems (due peak cylinder pressure and wear) if no adduced are used to correct the fuel properties.
Old Jan 4, 2019 | 08:23 PM
efzauner's Avatar
2005 C240 2011 R350
So you are assuming that without the DPF, the engine management will not kick in the DPF burn off cycle? I am not sure if it senses back pressure or if it is done via a drive cycle. What is your understanding of it?
you know of this site: http://www.stephensservice.com/bluet...ssuesproblems/
Yes I know you dont have the bluetech, but the DPF cycle should be similar.
Old Jan 4, 2019 | 10:01 PM
marc hanna's Avatar
The DPF regen cycle is initiated by the Differential Pressure Sensor. There are two bungs, one before and one after the DPF that connect airlines to the DPS to detect the exhaust pressure difference and determine when it is time to regen.
Old Mar 10, 2019 | 11:53 PM
Vince Brown's Avatar
r320
HI would you take $100usd and ship to california?THanks
Old Feb 19, 2020 | 03:59 PM
b-rizz's Avatar
2008 R320
Have you noticed any other gains with the dpf delete? Quicker spool, feel more free flowing/ more torque with the less restriction?
Are you still running OEM mufflers?
Always been curious what the best route would be as part of the DPF delete such as going bigger exhaust or high flow mufflers to get most power and fuel economy.
Old Feb 19, 2020 | 04:50 PM
marc hanna's Avatar
It’s hard to say which mod made the most difference, but there is roughly 30hp more and about 100ftbls more. It pulls strong to over 200kph but I don’t have any numbers for you I don’t notice any turbo lag at all.
Still the stock mufflers.
Unfortunely, the dfp is long gone and no longer for sale.
Old Feb 19, 2020 | 05:12 PM
b-rizz's Avatar
2008 R320
Yea those numbers make sense to me
I currently have the GDE eco tune and I’m thinking of doing the dpf delete from CB engineering same as you.
Just trying to figure out the best way to maximize this mod.
I see you’ve done the dpf mainly to save on oil which is a big upgrade in itself. All positive so far I’m seeing.
Thanks for the info
Old Feb 19, 2020 | 05:33 PM
marc hanna's Avatar
I’ve got the GDE custom/off road tune. I think you might be able to save some money and find a local custom exhaust guy for the pipe. I use Amsoil oil, and even after 20,000kms it’s still good.
Old Feb 19, 2020 | 07:08 PM
b-rizz's Avatar
2008 R320
Well that’s why she’s running so well! That Amsoil 👌🏽
