R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Leaking Trans fluid from under radiator pics*
Old Jan 5, 2020 | 10:45 AM
BenzBallin's Avatar
R350 2008 4Matic Gasoline
Anyone ever had this happend ? im leaking Trans fluid from bottom hose of radiator" ..pic attached..any insight ???
Old Jan 6, 2020 | 12:22 PM
BenzBallin's Avatar
Well no thanx to Anyone ...only thanx to my new friend G henry for re-affirming what i had to do" ...if ever that Line leaks then buying a new "Clamp" and ripping out the new one is what it takes to remedy this....if you ever have a small oil leak on the bottom front left of your "R" then you can purchase a new Clamp to swap it out" ..its located on the bottom of the radiator on drivers side" ..either way whenever one has time just check it if its not leaking just in case its slowly seaping out.."
