S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
1987 420 SEL cranks a lot before starting
Old Jul 2, 2008 | 10:16 AM
SL-ML-C's Avatar
2000 MR-S daily driver, 1997 SL600 weekend fun, 1999 ML430 tow vehicle
Hello all,
I bought a 1987 420 SEL thats in just fantastic condition, 165k on the clock, etc. for $1,100 but there is just one thing that doesnt seem normal, and that is the car cranks for a few seconds more than I think it should before starting, once its on, its butter smooth and everything is as it should be
anyone have an idea as to what it could be, or some common thing I should be looking at?
Old Jul 2, 2008 | 02:57 PM
tinypanzer's Avatar
300 Sonderklasse E
I don't know much about your car specifically, but this problem can occur in situations where your fuel filter is getting clogged, and/or the fuel pump is wearing out.
A simple fuel pressure test would tell you if this was the case.
Does it matter if the engine is hot or cold? Will this problem happen after parking the car for 30 minutes with the engine still hot? If so, then fuel delivery is even more suspect.
Good Luck.
Old Jul 2, 2008 | 04:31 PM
Untertürkheim's Avatar
Honestly, it could be any of the components that get replaced with service, distriutor cap, spark plugs, wires, fuel filter, etc. Do a full tune up and see if the problem gets better, otherwise, fuel check valves.
Old Jul 3, 2008 | 01:16 AM
SL-ML-C's Avatar
actually, I started it a few other times and I just think its not been driven in a while...
seems fine now, beautiful car in phenomenal shape.
un-related, how do I remove the headlight wipers and where to I get the 'blank' panels as I am going euro.
Thanks everyone!
-Erik
Old Jul 4, 2008 | 03:47 PM
SL-ML-C's Avatar
I was noticing today, when I leave stop lights stop signs, there is a fair amount of blue smoke (uh-oh) from my car, I presume this means my car is burning oil and it cant mean anything else (i.e. running rich, bad timing, fouled plugs, etc.)
the car still starts, runs and drives beautifully but this is making my a little worried.
Old Jul 4, 2008 | 05:18 PM
It could also be transmission fluid from a bad modulator. It would get sucked into the intake.
Old Jul 4, 2008 | 05:19 PM
Also, what type of oil are you using?
Old Jul 4, 2008 | 05:26 PM
SL-ML-C's Avatar
I'm not sure what type of oil it is, since I just bought the car I havn't changed it my self with my usual european formula oils.
as for the transmission fluid modulator, what is, where is it, and what does it do?
Thanks again!
-Erik
Old Jul 5, 2008 | 08:12 PM
SL-ML-C's Avatar
i added a quart of 10w30 dino oil today,
i should add some detail to my problem
>>seems to only happen when car is hot (80*c)
>>seems to only happen under 1,000rpm
>>if you start off very slow and build to 1,000rpm, there is no visible in the mirrors.
>>when the car is hot, the gas pedal vibrates (i can feel it with my foot) until pressure is applied to it
>> seems to still get good fuel economy, runs very well and still very willing to rev.
>> car starts and idles rough after for a few minutes after a drive where it was allowed to get to working temp but starts immediately and runs smooth if only driven to 60*c on previous trip.
>> the car used to have a K&N cone filter on it, could that have messed something up? i have since replaced it with a fram, K&N drop-in is next though.
any help, wisdom or possible causes would be greatly appreciated.... I hope its nothing major, I LOVE this car.
Thanks in advance!
-Erik
Old Jul 7, 2008 | 02:46 PM
SL-ML-C's Avatar
anybody?
I cant be the first to have this happen out of 10's of thousands of 420's
