S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
420SEL won't start... cracked valve cover..
Old 06-03-2009, 09:59 PM
jaaames's Avatar
420SEL
To start things off, I don't know a whole lot about cars but I'm good with my hands. I've searched and haven't found any good answers to my question.. Here's the story. So I go to start my car and it starts up fine and runs for about 2 seconds and I hear a snapping sound.. I figured it was the timing chain but it wasn't.. The valve cover is cracked but the chain looks fine and it's clean and tight - even when I try to start it. It has spark and the vacuum seems good. What should I check next??
Attached Thumbnails 420SEL won't start... cracked valve cover..-dscf2033.jpg
Old 06-04-2009, 11:24 AM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
Tensioner, rails, guides, sprockets you can name it.
Something did happen to the chain to allow it to crack the valve cover.
Have you tried cranking it over by hand?
Does it start and run?
Most likely not.
Old 06-04-2009, 11:35 AM
jaaames's Avatar
420SEL
Most likely not.
Well, I was checking it out again today and I found a small piece of the guide broken off inside, so that explains the crack. Although, I still can't find the starting problem. It starts but it just won't run - it shakes and sputters and dies. How depressing. How do I crank it by hand?
Thank you.
Old 06-05-2009, 12:15 PM
BENZITCH's Avatar
It must have jumped timing. Do not run it any longer.
It will need the chain rails and guides as well as the tensioner replaced.
Hopefully no head damage since it seems like it has jumped timing from one of the 2 cam sprockets.
Old 06-05-2009, 08:21 PM
harkgar's Avatar
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
Absolutely right.
I replaced my w126 timing chain at 100,000 miles and had done some research on this. The job is expensive. MB charged me about CD$3,000.00 at the time. New chain, new sprockets and "fingers" or followers, labor included.
If nothing is damaged and you intend to keep the car then you should do the repairs.
Old 06-10-2009, 08:42 AM
granit560's Avatar
1987 560 sec impala metalflake, over cream, or java.
you can do the job yourself, ( chain, guides, tentioner bolt, gaskets, plugs, ect. ), for around 600.00 parts, if there is no valve piston damage!
Old 06-15-2009, 02:13 PM
jaaames's Avatar
420SEL
Hey guys! I'm really sorry I haven't come back for an update, I've been very busy. Well, I'm tempted to do the job myself but I'm kind of afraid that I'll get half-way though and get stuck on something or mess something up. I've called around and everyone has told me it's going to be about $3,000 to fix. Can I check for valve damage myself? If so, what tools would I need? I really want to keep the car but I definitely can't pay $3k to fix it.
Quick Reply: 420SEL won't start... cracked valve cover..
