S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Coil Spring replacement
Old Oct 21, 2009 | 12:06 PM
Cherman Veels's Avatar
350 SDL
I am looking for informations regarding front coil spring replacement on a '91 - 350 SDL. I have the new coils and a quality spring compressor. Is it possible to remove and replace the coils without disconnecting ball joints?
Thanks, Jon
Old Oct 26, 2009 | 08:46 PM
350 SDL
Thumbs up Not necessary to disconnect
I used an internal type spring compressor and was able to remove and replace the coils without disconnecting the lower ball joint! CV
