S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
1983 300SD Klima A/C Relay location
Old Sep 17, 2010 | 09:24 PM
jastacey's Avatar
300sd
Can any advise me as to where the Klima/AC Relay switch is located , in a 1983 300SD .... My A/C is blowing hot air and the compressor will not engage, previous owner said that when he had the car, he changed out the A/C relay and that solved the problem
Old Sep 23, 2010 | 03:37 AM
Rasta126's Avatar
560sel(sold) 300sd(sold) Euro 280sel with 66k original miles, 96integra (sold), 2003 passat ( P.O.S)
It should be on the driver side right in front of the firewall, thats where it is on my SDL
Old Sep 23, 2010 | 09:47 AM
jastacey's Avatar
300sd
Here's an update .... after reading and reading and reading all kinds of info on the web, here's what I found out, the hot blowing air was solved by replacing the "Mono Valve" ... seems that some of the A/C circuits are keyed off of this part ...still trying to find the relay that controls the A/C circuit ... I'll recheck the firewall in front of the Drivers side.....
