S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
1985 mercedes air flow sensor plate flutters
Old Jan 1, 2013 | 05:47 PM
ChamaRiver's Avatar
1985 Mercedes 500 SEL
Question 1985 mercedes air flow sensor plate flutters
Does anyone know what causes the air flow sensor plate to flutter when trying to start. The car was starting, but after I changed the oil and filter the air flow plate started fluttering (open/shut) rapidly and the car would not start again, thought it tries.
Old Mar 2, 2013 | 10:27 PM
gretchen's Avatar
1984 5oo SEC
Cool fluttering of sensor plate
The sensor plate is held in position by a counter weight.Also a leaf spring is in place to return the plate to closed position.Spring may be weak.Weight may be out of adjustment.Also the air control valve may be very carbon embedded.
