S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Door Seal Leaks
Old Mar 6, 2013 | 04:30 PM
Jacktalkssmack's Avatar
1982 300SD
Door Seal Leaks
I have recently purchased (August) a 1982 300SD, I brought it to the mechanic and everything checked out - the car is in very good shape for being an '82 and not to mention one in New England
However - After a while I noticed rust on the door jams after opening and closing the doors and to my surprise I saw large pockets of rust and even fairly large holes under the actual doors - the door seals must have been leaking for a very long time
So my question to you is..
A.) Is this an easy fix?
B.) I have been searching and searching for door seal replacements but can only find the cheap ebay variety
C.) I plan on this being a project car next winter - should I ride out these doors and find four others from the junk yard to replace them? Or stop the bleeding and patch the existing ones - are these doors structural?
All and any help is greatly appreciated, Thanks
