S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
SRS Light
Old Apr 6, 2004 | 01:38 PM
MR500SEL's Avatar
500 SEL
SRS Light
The SRS light on my 84 500 SEL stays on. Any ideas on the cause? sensor - or bigger problem???
Old Apr 6, 2004 | 05:19 PM
Jer's Avatar
Jer
1994 E320
You need a pulse counter or shop-made LED tool to interrogate the fault codes. Then you can determine the problem. However, I'm not sure if an '84 has pulse readout. You might need to have a dealer or indie MB mechanic use the special airbag test tool and socket box.
