S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Fuel problem w126 500 1982, pressures
Old 07-15-2017, 12:52 PM
javimx5's Avatar
W201
Hi all
First to say that I've gone trough the forum and haven't found a related article on this matter, have just restored a Jan 1982 500 SEC and need some advise on fuel pressures.
Fuel pump, filter, injectors, etc are new.
I have attached fuel tester to WUR and I get back following values
-Cold : 1,8 kg
-Warm: 3,8 kg
- I close valve on line and get 4,6 kg
I have also attached tester to cold start injector line and get back 4,6 kg
Supposesly I should get 5.0-5.6 kg on the system.
Now the problem, car starts fine, on stand accelerates well but when on drive and pushing throttle more than 1/4 I get king of misfiring and lack of power getting worst when car is warm.
Any advise? Thanks for all your answers
Quick Reply: Fuel problem w126 500 1982, pressures
