S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Cruise Control will not “Resume” after braking.
Old 03-01-2018, 08:43 PM
kingofspades's Avatar
84 300sd (w126) diesel
on 84 300sd (w126)...
Cruise Control works fine, and when I brake, cruise dis-engages, as it should. However, after I brake, cruise will not “Resume,” or “Accelerate / Set,” or Decelarate / Set”...nothing. Simply, cruise control DIS-engages on braking, but will not RE-engage after braking.
To get cruise to work again, I have to turn the ignition off and restart the car. Then cruise control works fine again...until I brake again. Suggestions?
Old 03-02-2018, 11:16 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
You have a faulty CC stalk(switch)!
Old 03-02-2018, 06:35 PM
I already checked the Cruise Control SWITCH (126-540-0544) on the steering column. It's working properly (see below) so my CC Switch is not the problem...but it could have been, so thanks for your suggestion.
You can confirm that the Switch is working properly buy checking volts on the 14-pin (female) connector on the Cruise Control AMPLIFIER (002-545-1632 on my 84 300sd). With your ignition in Run or Start position...
pin...normally.....in Switch Position.......
1.....+12v........."neutral"..............+12v
4.....0...............ACcelerate / Set...+12v
2.....0...............DEcelerate / Set...+12v
6.....0...............Resume...............+12v
3.....+12v.........Off.......................0
Quick Reply: Cruise Control will not “Resume” after braking.
