S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
'89 W126 300SE. Poor throttle performance
Old Mar 15, 2021 | 02:52 PM
Cayman2k's Avatar
Merc 300SE
I have '89 W126 300SE and it has issue with throttle performance. It does not do 8.6 sec 0-60. It does idles and running good as it warms up. If it is cold start, it will have barely any throttle response. I would have to warm it up and pray I can gas pedal it at intersection to go. There is no get up and go with this sled. I have checked and replaced laundry list of items since it needed many items due to it's age. The engine revs and the transmission does shift. Throttle linkage, fuel pump, ignition, etc. all have been checked and replaced. The intake boot has been replaced and troubleshooting using smoke detection tool to validate vacuum leaks. I have fixed the vacuum canister that connects to the transmission for leaks and the J-hose which was cracked.
Any suggestions would be great, I was not able to see any past posts that would help me here.
Thanks all.
Old Mar 18, 2021 | 03:21 PM
Sean._.S's Avatar
S550
My brother's 420SEL had similar issues and it turned out it was a clogged cat.
Old Jun 9, 2021 | 09:28 PM
Cayman2k's Avatar
Merc 300SE
@Sean. Thanks for the info but it took me a while but I just removed the cat’s and tested it to no veil.
