S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Vacum pump
Old Aug 22, 2006 | 09:35 PM
zibsBenz's Avatar
94 S320 W140 sedan
Vacum pump
My vacum closing assist pump (located in trunk) gave up. Upon inspection this is what I found ... pic... Does anyone Know of a repair depot or where a replacement part can be purchased......dealer only wants to sell new pump assembly. Seems a waist to have to throw the whole pump away for such a small part. 94 S320 W140 sedan just clicked 290,000kms Vacum pump-dscf1152-medium-.jpg
Zibby
Old Aug 22, 2006 | 11:08 PM
NZ_Benz's Avatar
1993 300SEL/S320
Might be worth looking to get that one part fabricated by a local shop?
Old Aug 23, 2006 | 08:13 AM
pcmaher's Avatar
1995 S600 Sedan
That would be a difficult part to fabricate. It's a composite material. Junkyard maybe? Or post a "Wanted" on the various forums?
Old Aug 23, 2006 | 05:16 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
Close assist
As most can remember one of my major issues with my 92 500 SEL, is the vibration issue, and close assist pump issues. I have given up on trying to eliminate the vib issue, and have it down to minimal. I have gone the Bose and AC evaporator route, but every five years or so the closing assist pump goes.
In 96 or so they replaced it, and then also replaced the trunk latch since there was a service bulletin. The latch was replaced after the pump since the trunk acted up at N/C.
In late 01 the doors and trunk started again, MB replaced the pump (we had an agreement that I would pay if there was something defective). Well they lost, and it was a N/C, since they found nothing wrong (customer adjust).
Recently the trunk lid is not always pulling down (if you do the fuse thing it will work for weeks or days).
I hate to take the pump apart, I hate paying the $600, and am almost back to putting in a relay that breaks the cicuit to the fuse whenever the trunk light comes on, or a mercury switch when the lid opens. I will have to work on the logic a little, or just a push button so I dont have to open the door to remove the fuse and re insert.
No issues with the doors, maybe I will soak down the lock with cleaner.
A new pump always seems to correct it "for a while", its all those damm safeties...I threw away the last pump after three years, I probably should have done a "post mortem" to see what is in it. I pretty well understand the system, I have the DVD, have an electronics background, and have worked as a mechanic.
As to rebuilding one, there have to be take outs at MB dealers, I know there were rebuilders paying mechanics $50 for cores
Old Aug 24, 2006 | 04:40 AM
ajbristol's Avatar
300SEL (S320)
Don't think you'll find one of them anywhere BUT you may place a request for a faulty unit and recover the part ?? or as the previous poster listed get one fabrcated, may not be that expensive... maybe a friendly model maker type person may be able to knock one up in an alloy material failing that try the arodite route what have you got to lose.
best of luck
Old Aug 23, 2013 | 11:48 PM
alfredbutters's Avatar
500 s
Is there anyone who can simply describe where the pump is located that regulates the doors and trunk soft assist.
Ihave spent hours reading but no real answer as to where in the s5oo trunk this pump is located. if you have a picture
a picture is worth a thousand words. One simple diagram would make it so easy for a novice to follow. Help
Last edited by alfredbutters; Aug 23, 2013 at 11:52 PM. Reason: poor typing skills
Old Aug 23, 2013 | 11:57 PM
500 s
1999 e320 key fails to work upon initial turn. Ignition turns over on second attempt. What may be causing this? Do i need a new key? ar the ignition system is worn out 134000 miles on the car. Help
Old Aug 24, 2013 | 12:01 AM
500 s
What is the cost of a replacement motor for the rear window sun screen. It ha sstopped working and I do not know if it is the fuse or the motor. help. thanks. it is an e320 1999 4 matic
Old Aug 24, 2013 | 04:39 AM
oldsinner111's Avatar
s320
alfred I had to replace my ignition switch not to hard of a job.Buy the best part,no URO
Old Aug 24, 2013 | 04:40 AM
s320
alfred try the benzworld forums in the w140 section.zidbenz you can find trunk pumps in wrecked cars,I've never heard of them being replaced as they can be adjusted
