MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   S-Class (W140) (https://mbworld.org/forums/s-class-w140-29/)
-   -   Trunk won't close (https://mbworld.org/forums/s-class-w140/54074-trunk-wont-close.html)
TBRUENN Dec 3, 2003 08:40 AM
Trunk won't close
I have a 95 S320 and the trunk won't close all the way. It locks but the auto close function is not operating. Any ideas on how to fix? I s this a common problem?
Thanks in advance
Tom
TBRUENN Dec 3, 2003 09:05 AM
Please disregard this post. I did a better search and found some answers.
Peter Guenther Dec 4, 2003 08:26 AM
trunk
Pump, or check lower latch (adjustment) for loose screws.
TBRUENN Dec 4, 2003 08:30 AM
Thanks Peter I will check it out!
Tom
Peter Guenther Dec 4, 2003 12:56 PM
Trunk close assist
Provide some feed back if you cant resolve, I understand the system somewhat.
killerbee Dec 13, 2003 01:47 PM
Most likely your vacuum pump assembly has gone bad and you need to replace the whole thing. It is located in the trunk and has numerous vacuum ports on it. Be careful removing it.
© 2026 MH Sub I, LLC dba Internet Brands
