thornethree43 |
03-12-2019 12:03 AM |
95' S320 Door locks and soft close not working
I am having an issue with my 95 Mercedes S320.. It seems to be a common problem but I need a bit of clarification.., While reading some posts searching for the correct fuses have been challenging, Some posts says to look behind a door light behind / under the right passengers seat for a fuse, i have not found a fuse panel under there, nor have i found a fuse panel under the rear seat on the right, only the central pump system is there.. I have found the fuse panel under the left side hood near the firewall where #5 fuse is powered and directs to the fuse box in the trunk..., In the trunk fuse box I have checked fuse #11 & #3 which both has power..., Is it safe to assume that the pump under the back seat is bad or should I be checking something else? Also, Has anyone had any issues with rough idle AFTER changing out the biodegradable main wiring harness?
Thanks in advance
