S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1996.06 s600 w140 starts 5-7 sec and dies
Old Dec 8, 2024 | 04:24 AM
Rex1234's Avatar
s600
Hi
Please help me to solve this weird issue with the 1996.06 S600 W140.
The car starts, and for the first 5 to 7 seconds it runs well, and I can rev it up as well. The engine sounds perfect. Then the engine is stopped suddenly. Only the fuel pump can be heard for another second. I can do this endlessly.
Checked things
Connectors for ecus and other modules under the bonnet and in the trunk. Perfect, no water damages whatsoever.
Fuel pressure with an external gauge. Pressure Stays up for couple of seconds after engine cuts out 3-4 bars.
Not a DAS issue. Try a car without the transponder in the key, and it was a different story then. It cranks but is not firing up.
No faults in left or right ecus
All fuses are good except under the hood Fusebox fuse f21 blows - its for exterior equipment traced from WebETM should be short circuit in mirrors i will deal that later.
What else?
What can cause that sudden stop after 5 perfect running seconds?
Please advise.
Thank you
Old Dec 9, 2024 | 09:31 AM
bborden51's Avatar
1993 600 SECw140
Fuel pressure doesn't hold up after it dies? Hmmm. But fuel pump runs for another second then quits...sounds like it pressures up but then pressure drops. Have you checked the fuel pressure regulator? Vacuum hose attached? Strange.
Old Dec 11, 2024 | 03:10 PM
JohnLane's Avatar
222 S-65
Look for the relay that is turning off power to ignition, fuel.... monitor power to coils, injectors.
